Building Lake Corona
/ Building Lake Corona #181
I think it will be interesting to follow this project through a year or so of seasons and see your management/maintenance activities.
Me too. I'm looking forward to it. Great Corona Project!!!
Hopefully this project doesn't come to a quick end. I'll check the water level in a couple of days. Not sure what to expect at the moment with such a small amount of initial water to monitor. With the temps in the 60's to low 70's I shouldn't loose much if any to evaporation. If it's gone in a few days I'll know the soil doesn't have enough clay mix. If it's still there I'll continue on when dry enough.
/ Building Lake Corona #183
Good plan. I'd hate to see you devote more time and resources to a Lake that won't hold water.
I'm optimistic though!!! I think it'll be a success.
/ Building Lake Corona #184
It's only at about 6 feet right now. I would love to take it to 15 feet at the waterline but that is going to involve moving a whole lot of dirt. I may have to look at renting a dozer for a week.
Have you checked the area behind the dam for seepage? Ideal slope for pond slopes is 3-1. So a dam 15 feet tall would be 45 feet wide at the bottom of the slope. That is just one side of the dam. Both sides would equal 30 feet at the base. That would be awesome if you have the room.
Moving lots of dirt gets to be monotonous. I know. Just spent the last 4 days moving dirt and spreading it on the dam for a little more height and width at the top. 4-14-20 Pond With Dirt Pile.jpg4-14-20 Dam From Fence Line.jpg Also seeded with Bermuda grass seed. I pumped the level down to move the dirt and install cinder blocks in the swallow end for Fathead minnows. Now, I look forward to rain.
hugs, Brandi
/ Building Lake Corona #185
I would say so the one picture showing it holding water looks promising .
/ Building Lake Corona #186
Moving lots of dirt gets to be monotonous. I know. Just spent the last 4 days moving dirt and spreading it on the dam for a little more height and width at the top. View attachment 651610View attachment 651609 Also seeded with Bermuda grass seed. I pumped the level down to move the dirt and install cinder blocks in the swallow end for Fathead minnows. Now, I look forward to rain.
hugs, Brandi
You have done a excellent job on that pond bindian . . . :thumbsup:
/ Building Lake Corona #187
I agree!!!! My biggest concern was water permeating thru the rock layer in the base of the ditch. That would be very obvious. If there's not a noticeable trickle of water escaping under the base I think he's good. Hope so for sure!!
So far so good. Just walked back to take a look. Made 1" marks on the pole so I can keep track. I've lost 1/4" in 24 hours. I built the bottom of the pond about 4 feet higher than the rock shelf I hit so the back side of the dam is much lower than the front side. No water on the back side at the moment.
2020-04-18_06-10-42
/ Building Lake Corona #190
It seems to be holding so far....so good. Hope it holds.
I wonder if all the traversing with the skid steer packs it down to help it hold water?
Brandi, your pond is looking great.
/ Building Lake Corona #191
2020-04-18_06-10-42
Looking good!
:thumbsup:
/ Building Lake Corona #192
You are good. Should have lost more than that if leaking!!!
Congrats!!!
/ Building Lake Corona #196
Great drone videos, JK 96. Good job on the "Lake Corona" project. I just have my 5 acres here, but we enjoy it a lot. I am usually too busy working as a substitute teacher in our local high school (supplements my pension so I can buy important stuff like tractors), but that is out for now, so we are out most every day re-opening walking paths through our woods. Amazing how quickly that brush takes over.
Hi Mike,
Thanks. I agree on the brush. We have some pretty wicked timber here in places. I've done a lot of clearing the last year getting it to the point where it's easier to walk. I've been especially focused on getting rid of all of the honey locust along the field edges.
This morning the water is down about 1/2" total over 36+ hours. You can see the one inch mark under the water surface in the below pic. I expected more just from the soil taking in water and getting saturated so I think I'm good as far as being able to seal the pond well with the dirt we have. My next step will be clearing all of the brush and timber that will be inside the final water line then removing top soil. The 2nd picture is looking north from the dam. This is the area I think I'm going to pull dirt from for building up the dam. There is more than enough here for what I need and will also increase the size of the main pond area.
2020-04-19_08-55-17
2020-04-19 (2)_LI
/ Building Lake Corona #198
Yeah, if you can, pull dirt from the pool area.
Thanks for more pics. I'm pleasantly surprised the water level didn't drop any more than that!!!
Any idea how many acres drains into it.
It looks like there is about 15 acres that drains into the pond area which usually means it would support a 1 acre pond. This one should be about 1.5 acres when finished.
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
2022 EZ-GO ELITE...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2017 International HX620 Quint Dump (A62613)
2017 International...
