Hey All. I have seen threads that touch on this but I知 looking for advice and guidance on what would work best for my application. I知 on 5 acres with grass, hay and weeds in eastern Colorado so moisture is low and growth is slow. I have some landscaping to mow around with very few trees. I was originally looking at brush hogs because that痴 the only thing I knew but then finish mowers caught my attention. My land does have some holes, high low spots and I知 sure sporadic rocks and debris. Yesterday I was reading another thread on here and learned about flail mowers so I知 digging into the pros and cons of them. From what I gather, maintenance and cost may be higher but it is safer, leaves a cleaner cut and it better in tight areas than a brush hog? It is better for tougher land and debris than a finish mower but won稚 leave as clean of a cut. I could care less if my grass looks cut or chopped but I will need to knock this stuff down so if I can make the best of what I have I知 all game for that. I知 a tractor and attachment noob so any advice would be appreciated.
I知 running a Ford NAA
