Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,080
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Just a PSA to anyone that has a leaking cylinder and is preparing to take it to the shop.
Try it yourself first. I had taken several of mine to the shop over the years to have new seals installed. I thought there was something difficult about it.
I finally had my crowd cylinder off machine (and could barely carry it myself) and decided I really had nothing to lose AND, I'm sort of adventureous on taking things apart. Carrying it was the hardest part.
Over this past weekend, I did the two stabilizer cylinders.
What I've found (given the design of these cylinders) the hardest part for me after carrying them was removing and replacing the piston seal. That was a little bugger to install.... but patience and persistence did it.
I pinned the rod back to the foot of the machine so the machine would hold the rod steady while I tightned it down (also did it to loosen it).
No special tools other than pipe wrench to unscrew cap on end, then it was clean up, new gaskets and put back together.
There is a bit of a mess but I did my best to drain cylinder prior to taking apart. Got 99% of the oil out.....but still got some on ground.
I wish someone had slapped me upside the head 15/20 years ago when I was dragging cylinders down to the shop, waiting a week or so while THEY sent it to ANOTHER shop to actually do the work (I didn't know this at the time).
You can probably do it yourself and will save yourself some cash.
