TD7E Rebuild Project
/ TD7E Rebuild Project #1
hawk10
Member
Hixson, TN
John Deere 3033R, Dresser TD7E
Hey guys, I am relatively new to this forum and this is my first new thread so I hope that I do it correctly.
I have taken on a project to rebuild a 1982 (I think) TD7E Crawler, it has lost most of its power and will really only move in 1st gear (forward or reverse), it uses about 1 gallon of motor oil per 5-6hrs of run time. The battery doesn't charge so it has to be on a charger before use, and it wont start without using significant amounts of starting fluid. (This is just a start to the list of problems it has) I know that it is old, parts are hard to find, and that it is probably not worth the money that I am planning to put into it but this dozer has some sentimental value to me. My grandfather bought it and let me drive it while doing some projects around his farm when I was about 10 years old. I felt like superman on that dozer back then and it was some of the best memories of my childhood hanging out with my grandfather. One year at Christmas, not long before he passed away, he gave the dozer to me because he was getting too old to use it and he knew that it meant alot to me.
Now, I live in a neighborhood and I have only about 1 acre so I haven't really done much with it up to this point, it was sitting for a long time under a shed on the farm. I decided that I did not want to let it rust away so I am going to rebuild it little by little over time until I have a semi-restored piece of equipment. Over the weekend, I brought the dozer to my house and walked it up my driveway on boards, took the cage off, and then put it in my garage. (My wife was very excited about this :laughing:)
I have started working into the engine little by little, taking pictures at each step so that I can remember what order everything came off in. I am planning to do an in-frame overhaul but I have a few questions that I hope someone on here could answer for me. For some extra background, the dozer is a 1982 I think, and it has 4,245 hours on it, also I do not know if it has ever been rebuilt or had work done to it aside from the undercarriage.
From what I can tell, it would be very hard to get the torque converter out without removing the engine. My question is, how robust are these torque converters on equipment like this, I have no reference. To rebuild the whole engine, new parts are probably going to run me around $1200 with new fasteners, hoses, pumps, etc. These torque converters are around $3000 for a rebuilt one not including a $1500 core charge. Do I need to change this converter too or is it likely ok for a while? If I do need to do work on it, how hard is it to rebuild a torque converter? The transmission looks like it would come out without removing the engine so I will probably just leave it at first, I plan to go through it also but I do not have the $$$$ right now to do it all at once.
At this first stage I am planning to do the following, please chime in if there is something that you would add to this, I would like to only be into the engine once if possible:
> In frame engine overhaul (sleeves, pistons, rings, rod bearings)
> Rework head
> New water pump (coolant was full of rust chips)
> New oil pump
> New hoses/belts/fasteners
> New undercarriage front idler (wobbles back and forth like the bearing is gone)
> Change ALL fluids (engine stuff obviously, but also all hydraulic oil and filters)
Hopefully after the first stage the dozer will be operational so that I can use it if I need to, I am going to work on the following second stage after it is operational, little by little:
> Rebuild hydraulic blade control valves and linkages
> Rebuild hydraulic cylinders
> Replace all bushings for blade and cylinder attachment points
> Rebuild transmission
> New brakes
> New tracks
Finally for your enjoyment here are some pictures of what I have found so far as I have been taking apart this engine, I will post more as I go.
/ TD7E Rebuild Project #2
Converter is o.k. if it moves strong and the shift is solid. The 7 is a nice dozer, handy size and easy to run. I would say engine removal for converter removal. I used to have several TD-9's, older ones, didn't care much for them, always broke down, Still have the TD-250-C loader, 573 turbo V-8, power shift, power steering and 4 in 1 bucket. My wife named it MOOSE. I did a lot of heavy work with it over the years.
Did bid on a 7 one time, but the oil leaks scared me from going very high!--still think they are a nice unit!
Thank you, I was unsure if these converters were mostly fluid coupled or if they actually had friction plates in them like a lockup converter. I also have no idea of how robust they are so this will save me alot of money. The shift was sharp and strong in 1st gear forward or reverse but not in any of the other gears before I took it apart. It would push in first also but not as hard as it used to, I am hoping that is mostly engine and less transmission but we will see.
A TD-250-C is a serious machine, I have never operated one before but I bet that it is nice to have something that pushes like a dozer but also has a FEL.
I have another question, does anyone know if the engine can be removed without removing the torque converter? I was wondering if it would be possible to detach it from the flywheel and remove the engine while leaving the torque converter in place. I have been debating on including the main bearings and seals in the overhaul but I am not sure if I should do it all or not. There isnt that much cost difference in the kits but it could be a tremendous amount of work if I have to remove the torque converter. If I see anything on the crank when the pan comes off I will go ahead pull the motor, but if the crank looks good should I just leave the crank and the mains in place?
Here are some more pictures of the progress so far:
/ TD7E Rebuild Project #5
Depending on the number of hours on the motor, how long it has sat without running, etc. IF the crank seals are not leaking, you could leave them, but with all of the work you have planned to do on it I personally would pull the engine and go all the way on the rebuild. I cant find out if engine will come out without converter. Not sure if it would be same procedure as a 250 or not. I have the complete set of books for it.
In the past I had 3 or 4 older TD-9's but they were all direct drives.
A couple pix of "MOOSE" , all 60,000 pounds of him!--- LOL!!!
Ok guys, I apologize for taking so long to update this again, I got into the project started and never followed up with posts, I have actually completed the engine rebuild and got it put back into the dozer. I am going to post this in pieces because it crashed when I tried to put them all up the first time (I wish there was a way to bulk upload these):
Here is pulling the motor with the tractor:
Here are some pictures of breaking down the motor (If anyone wants to see more detail of something let me know, I have a whole lot more pictures than what I am posting):
2019-12-28 15.06.37.jpg2019-12-30 22.37.25.jpg2019-12-30 23.16.25.jpg2019-12-31 11.16.05.jpg2019-12-31 11.16.16.jpg2019-12-31 11.16.25.jpg2019-12-31 13.11.05.jpg2019-12-31 13.11.10.jpg2019-12-31 13.11.17.jpg2019-12-31 13.11.21.jpg2019-12-30 16.39.57.jpg2019-12-30 16.39.41.jpg2019-12-30 16.27.33.jpg2019-12-28 15.08.12.jpg2019-12-28 21.17.17.jpg2019-12-28 21.59.23.jpg2019-12-28 21.59.34.jpg2019-12-28 21.59.46.jpg2019-12-28 23.41.29.jpg2019-12-29 22.22.10.jpg2019-12-30 16.17.47.jpg2019-12-30 16.26.09.jpg2019-12-31 13.11.30.jpg
Edit: I apologize that these are not in order, I just tried the attachment function.
Here are some pictures of the cylinder head disassembly along with the cleaning of the block and cylinder head, this is the point when I started moving in the other direction (assembly instead of disassembly):
Just kidding, here are the pictures of removing the linings with the puller that I built, this was the last step before starting assembly:
Rocker arm shaft disassembly and cleaning along with linings, main bearings, timing plate, cam, and crankshaft installation:
New pistons, rod bearings, rod bushings, and rings. New oil pump installed along with balancer. Cylinder head reassembly with new valves, valve springs, valve guides, valve retainers, and valve seals. Rocker arm shaft reinstalled and injectors cleaned and installed so at this point it is ready to bolt back on the motor. Idler gear installed and all components except injection pump timed.
/ TD7E Rebuild Project #12
:thumbsup: Keep updates coming. :)
Injection pump installed and timed, timing cover installed, new water pump and water passage cover installed, rear main and front main seal installed. Several other parts installed, motor at this point is ready for the cylinder head to be installed:
Cylinder head, new exhaust manifold, intake manifold, fuel filters piping assembly, valve cover and fan installed. At the end of this it is basically ready for paint:
Engine and engine bay painted, motor installed along with other parts (we scratched the engine bay when we were putting the motor back in but I touched it up afterwards):
I did a poor job photo documenting this but here are some images of where I changed the track adjuster seal, let me tell ya this right here was a fight to say the least! Also there are some images of the dozer with all of the body panels installed and basically ready to go besides the cage. I still had alot of work to do at this point but I couldnt help myself, I had to do a project:
Here are some images of me getting it out and clearing out a small area on the side of our property, this was a happy day for me even though there is still alot of work to be done:
Like I said before I have alot more images than this so if you guys want to see something from a different angle I probably have a picture, just ask me and I will post it.
I am almost done posting about this but it wont let me upload anymore images. Does anyone know if when you delete a file from the upload manager, does it delete it from where you used it in a post or does it leave it there?
/ TD7E Rebuild Project #18
Great work! Nice to take it out and push some dirt after all that. Looks like you may be in for a little bit of track work in the future.
Yeah it was great to actually do something with it after a month of working on it for sure! It for sure needs track work, probably a borderline complete new undercarriage honestly but I am going to limp it by until I get the money to do it. Right now I have backed it into the garage to change all of the other fluids and filters, when I pulled the transmission suction screen I found these. They look like rivets but I am trying to figure out where they came from. Unfortunately, I think it means that I am going to be breaking into the transmission and steering system soon.
/ TD7E Rebuild Project #20
On your dozer does the gear box and transmission share the same reservoir?
(2) Planter Boxes (A66408)
(2) Planter Boxes...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
2007 Freightliner FLD120 (A62679)
2007 Freightliner...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
Woods Cadet MD172 Pull Type Mower (A66408)
Woods Cadet MD172...
