Kubota OEM top link bent
   / Kubota OEM top link bent #1
Tomtint
Elite Member
Boston
L3700SU
So somehow I bent one of the threaded rods on my top link. Not bad enough so its unusable..but bent none the less. Called my local dealer to see if I could get just that one end and I can...for just about $125.00.......Went to my local TSC and picked up a whole new top link for like 35.00, ...Apparently Kubota is fairly proud of their little threaded rod...
   / Kubota OEM top link bent #2
Yes they are........
   / Kubota OEM top link bent #3
Must be orange paint.;)
   / Kubota OEM top link bent #4
So somehow I bent one of the threaded rods on my top link. Not bad enough so its unusable....
If it's still usable it can't be bent too bad, why would you be so worried about it, that you replaced it??
SR
   / Kubota OEM top link bent #5
That's an expensive screwed rod.
I bent the right lift arm adjuster on (I think it was) the JD 4010. It still worked, but a pain at times. Have no idea how I bent it.
Ralph
SR
If it had to retract to fit in a shorter opening...it may have been a problem. Not all my implemints are the same length TL. I just know that I would have needed to adjust it someday and wouldn't be able to... Rather have it and not need it than need it and not have it.
   / Kubota OEM top link bent #7
OEM toplinks and parts for them are high. Fortunately aftermarket replacements are cheap and plentiful.
   / Kubota OEM top link bent #8
What bends them? In compression and buckle?
Somehow rear tires enters a dip and weight of tractor rests on implement (and through top link) because 3 point hitch parts don’t rotate quick enough?
   / Kubota OEM top link bent #9
I have bent them back, especially with that asian steel, it's pretty soft, compared to most of the others...
Straighten it, and you will have a spare.
SR
   / Kubota OEM top link bent #10
I had one fall out of the holder while the implement was off. It was long enough to reach the ground and got bent going backwards.
Informational Lot - Shipping (A56436)
Informational Lot...
2008 CMTL Trailer (A55973)
2008 CMTL Trailer...
NEW Wolverine 84in High Capacity Pusher (A59000)
NEW Wolverine 84in...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
406 (A52706)
406 (A52706)
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2019...
