CK2610 Hydro fluid change Hours??
/ CK2610 Hydro fluid change Hours?? #1
tiogajoe
Little Marsh, Pa
Kioti CK2610hst
Can't seem to find my owner's manual? Have to look in the Barn tomorrow? I changed My Hydro fluid and filters at 50 hours. Is the next fluid/filter change at 400 hours? At 260 hours now. Fluid looks nice and clean. Thanks.
/ CK2610 Hydro fluid change Hours?? #2
Its at 400 hours for transmission fluid. filter at 200.
I have new filters. I did change the fluid again at 170 hours to JD Hygard because I wasn't happy with the cold weather performance of what I had in there. I did not change the filters though. Do you lose a lot of fluid just changing the filters?
/ CK2610 Hydro fluid change Hours?? #4
Here's a scan of the maintenance schedule chart from the CK2610 owners manual:
I could see 200 hrs changing the filter again if you kept the factor fill hydro fluid? Kinda seems like a waste if you also changed your fluid along with filters at the 50 hours? Oh well, i'll change out when the weather clears.
/ CK2610 Hydro fluid change Hours?? #6
I can see that Kioti maintenance docs have not gotten any less confusing. My CK30 has different reqs in the OM, the service manual, and in stickers on the tractor.
I think a good rule for any HST tractor is to change engine and hyd fluids/filters within 50hrs of new. Then, 400hr is a good rule for change interval for the hyd fluid and filters. That means at 450hr if you changed at 50. I also like 100hr service interval for engine oil & filter.
/ CK2610 Hydro fluid change Hours?? #7
I agree entirely.
Most HST Kubotas I'm familiar with also have a 400hr change interval. Across all makes/models with HST you'll see very similar. These new tractors are not like granddads Ford 8N, that could go a lifetime without change. The convenience of these hydrostatic pumps/motors, and high output diesel engines, comes at the cost of more frequent oil changes. A small price to pay for how much faster, and convenient to operate, these new tractors are.
After speaking with my Dealer, I'm going to do just that.
/ CK2610 Hydro fluid change Hours?? #9
I used Kubota SUDT2 in mine, very good choice for cold climate.
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
