Source For Thin Utility Pliers?
   / Source For Thin Utility Pliers?
Use the fitting that are metal in future...
Dale
Is there a metal hose end repair available that doesn't use a hose clamp? Screw type hose clamps are the pits.
   / Source For Thin Utility Pliers? #12
I agree the screw type clamp is not a great setup but they work. Don't know much about PEX joints, but I found some brass male ends that you should be able to use the PEX clamps on. That would be a very near hose end.
Yes, a pex or sharkbite type end would make sense.
   / Source For Thin Utility Pliers? #14
Would anyone know of a source for thin jaw utility pliers as shown in photo PLIERS-1 below? I run into a problem when trying to tighten garden hose connections occasionally where a thin nose pliers would help out. I once had a pair of ceetee (crescent brand) narrow jaw pliers that disappeared some years back.
Yes, I know that problem. I have it every time I do some garden hose work, too. Luckily, there's a pair of old thin jaw mechanic's pliers in my toolbox - probably from my father, and probably WWII vintage.
They still make a mechanic's pliers with thin jaws. It looks just like a regular mechanic's pliers but has a thinned head. Go to McMaster.Com and enter "Tight-Clearance Slip-Joint Pliers" Cost less than $20.
My old pipe pliers by channel lock also has a jaw that is thin enough to work on that garden hose joint. In fact, that's the pair I usually pick up for garden hose work, but my wife prefers the thin jaw mechanic's pliers.
rScotty
   / Source For Thin Utility Pliers? #15
Have any of you guys or gals gone to a quick coupler system for your garden hoses and accessories? I've tried them a time or two in the past but never too happy with them. Maybe there are better systems available nowadays?
I've used both the brass and plastic ones. They're OK. You can crank them on the hose ends to eliminate leaks, but I've had them leak at the QC. At least with the brass ones, you can replace the internal washer which is a special type and not as easy to find.
   / Source For Thin Utility Pliers? #16
Years ago, whilst working in a factory, I made a pair out of flat steel plate. Some of the lads see them and I finished up making about eight. I`ve still got them in my tool box. Don`t tell the boss. I made them in the firms time.
   / Source For Thin Utility Pliers? #17
This is what I use, needle nose vise grips:
   / Source For Thin Utility Pliers? #19
I've had this same problem with garden hoses, and after fighting with the worn out fittings (slipping and spinning) for years I finally cut them off and replaced them. I was stupid for not doing that much sooner. Now I keep a few replacements on hand, and the first sign of problems I replace them. I mainly use the plastic type, but last year I used some heavy duty brass and aluminum styles on a couple hoses. The metal styles look nice, but they cost so much more than the plastic I don't know if they are worth it. I also replace the hose washers regularly, so between the newer connectors and the fresh washers, finger tight is all that's needed for drip free seals.
   / Source For Thin Utility Pliers? #20
I've also learned to replace the fittings rather than fight with them. Yes, replacing hose washers frequently is one of those tricks you learn after awhile. It beats me why someone doesn't make a better quality rubber hose washer - more elastic and longer lasting.
Someday I'm going to outfit one of our hose lines with quick connectors and set up a test to see just how much pressure and flow it costs to use that type of connector.
rScotty
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
New 4-10-16.5 Forerunner Skidloader Tires & Rims (A50775)
New 4-10-16.5...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2014 MACK ELITE...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2016 Freightliner M2 106 Braun Ambulance (A55788)
2016 Freightliner...
