TYM vs LS
/ TYM vs LS #1
4tillingdirt
nc
N/A
Anyone do a comparison between these 2 when looking for a larger compact - at least 35 HP? I have been looking at the T series TYM and the XR series LS. One advantage I think TYM has is no engine computer - just one for the DPF.
/ TYM vs LS #2
I compared the T394 and T454 with the XR3135 and XR4140.
The TYM was cheaper, by a decent amount, but came standard with less (e.g., only 1 rear remote, no telescoping rear links, etc.). The biggest thing I didn't like about the TYM was that the placement of the rear remote lever was in a really awkward location (on the floor). It seemed like there were just a lot of small things like that, which made it seem like the TYM just wasn't quite as well thought out.
I ended up getting the XR4145HC and haven't regretted it once. I'm at 45 trouble free and regen free hours since November 2019.
/ TYM vs LS
Yeah I noticed the LS tractors are quite a bit higher. I believe I was quoted around 28 or so for the 4155 open station and loader.
/ TYM vs LS #4
This does not seem to me to be an optimal setup. The mechanical fuel injection system can only be optimal over a very narrow range (if at all). A computer controlled common rail fuel injection system can be optimal over a wider range. This combined with the computer controlling both as a coordinated system, means overall less soot and particulate production, placing less demand on the DPF and better fuel economy.:2cents:
/ TYM vs LS #5
The Ls does come much better equipped than the tym. But for 2 or 3 grand you could buy some nice implements.
/ TYM vs LS #6
I own 2 tym made tractors and like them both. But my buddy recently bought a new xr 4140 and it is very nice.Lots of upgrades over the tym. But for the 2 or 3 grand difference you could get some implements.
/ TYM vs LS
Do you think the LS is more comfortable? I have read several threads about people wishing the steering wheel was higher on the LS.
/ TYM vs LS #9
My guess is it's a personal issue, which is crucial when it comes to discussing ergonomics. If you haven't done so already, be sure to sit on both and find out what works for YOU, not for someone else.
Some people complain on the LS the cab doesn't have quite enough head room and the cab is a little more cramped. This was a plus for me. I'm 5'10", and don't need a lot of space. Instead, the lower cab allowed me to size up and get the XR41XX series which fit in my garage.The T454 was a couple inches too high. Otherwise, I may have ended up with it.
Again when it comes to ergonomics, find what works for you, not, someone else.
/ TYM vs LS #10
The mechanical pump will last 100 years without a hick up. On a tractor that is designed to run at wide open high rpm, it is optimal
  • Good Post
Reactions: HEC
/ TYM vs LS #11
It’s an advantage for the future!
I would take anything without a computer dependency for fuel delivery over one with any day. When the system gets old and has problems you just remove it and keep going! With the computer you will be at the mercy of $$$ and depending on age parts availability no matter the make of the machine.
/ TYM vs LS #12
Overal height of the cab being lower would be attractive to me also. Sometimes I like to park in the garage rather than walk back from the barn and being able to fit makes a lot of sense. Really how much space does one need between thier head and the roof?
/ TYM vs LS #13
Having a little space for bumps is nice.
/ TYM vs LS #14
I haven’t operated anything smaller than the 35 hp range LS tractors but had no issues inside them or the 40 hp and they both would have just fit under the garage door.
Also I own a tractor so I have a tendency to fix the bumps on my property making them a non issue anyway!
/ TYM vs LS #15
TYM is a good tractor, the problem in my area was the lack of dealers, so I ended up with a Massey, which is made by Iseki. TYM and Iseki have some relationship as some of the TYM's designs are the same as Iseki's older models.
One of the best things about the TYM's are the Yanmar engines. They are great engines, they start great and last forever.
/ TYM vs LS #16
Got some seat time on my buddys xr 4140 the other day. I was very impressed with how smooth it rode and handled, the hst was also quieter than mine.
New Quick Attach Power Spreader (A65579)
New Quick Attach...
STEPP SEALCOATING MACHINE (A59914)
STEPP SEALCOATING...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
TEST YOUR BID BUTTON! (A64277)
TEST YOUR BID...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
