Gravel road: Filling potholes with concrete????
/ Gravel road: Filling potholes with concrete???? #1
FTG-05
Elite Member
TN
Kubota L4330 GST w/FEL, Kubota RTV-XG850, Kubota ZD326S
I live at the end of a one mile gravel. Since I moved here in late 2013, I've been maintaining the road as have the previous owners of my property (the only owners of a tractor).
I finally was able to get out and do some work after all the rain we've had the last 6 months. In that 6 very rainy months, a lot of potholes developed. So I took my BB teeth to dig down and break the hard pan and get down to the bottom of the holes - as I normally do every spring. I did this on Wednesday. On Thursday, while using my rock rake to smooth and groom the road, I ran into one of my neighbor's. We started talking and he said he and his wife had been going down the road and filling the potholes with concrete and then raking gravel over them. Of course, when I took my BB down the road, it dug up and broke up all the concrete he had put down. He made it sound like a lot of concrete - when I asked him to show me, we only found a couple 6-8 inch pieces.
I asked him if he planned to concrete the whole road (of course not). I explained that filling potholes doesn't really solve the problem of why potholes formed in the first place (i.e. usually water) plus it prevents maintaining the road - which entails more than just filling potholes. And, as we found out here, maintaining the road will just tear them out.
I've reviewed a couple gravel road maintenance .pdfs I have including 003-07-NPS-gravelroads-sec1 (that is it's saved title, there is no title page), and Gravel Road Maintenance Manual (Maine DEP and Bureau of Land and Water Quality). The first doesn't mention concrete at all; the 2nd only in the context of crushed concrete.
When I started this gravel road work years ago, I spent a lot of time both here and on YT learning how to maintain my road. In all that time, I have never read or seen anyone mention filling potholes with concrete as a solution to gravel road maintenance.
Comments, suggestions?
/ Gravel road: Filling potholes with concrete???? #2
I have never heard of it either.
Maine DOT will spread cement (not concrete) in powder form over a VERY tricky wet spot, glade it in with the gravel, with the moisture in the ground setting up the concrete to make a firm base, but they do it very, very, sparingly. Well I should say, I have only seen them do it once, and it was a swampy area.
I would just maintain the road like you have been, it seems like you know what you are doing.
Myself: I have an ever growing network of gravel roads myself. When I took over this farm in 2008, I would have to haul wood from stump to roadside by over a mile, but now I have snuck some all season, heavy haul roads back into the woods, so life is getting better.I figure by the time I get them all done, we will have hoover trucks, tractors and cars! (LOL)
If you are looking for more road information, the US Forest Service has a lot of information on roads too, and how to maintain them; in PDF Format, and in YouTube Videos. They use graders in their videos, but you can get some pointers nonetheless.
/ Gravel road: Filling potholes with concrete???? #3
Now that I think about it, they do have EarthCrete, which I too have done. I have a gravel pit so I use gravel instead of soil, but if a person wants to make a concrete pad on the cheap, they can buy bags of Portland Cement, spread it evenly over the ground, then take a rototiller and mix up the soil/cement powder. Moisture in the ground will harden it eventually. Or, a person can add water, and then mix it up with their rototiller.
It goes without saying that after the mixture is churned up, you screed and trowel it like you would any concrete slab.
It is just a lazy-mans way of avoiding the use of a cement mixer.
(Note: for "blocks" you can do the same thing, but put the dirt/cement mixture in paper bags. Eventually they will harden into a block. Eventually the paper will disintegrate. This works good for "blocking" up around culvert ends and such.)
(Note 2: For "lightweight concrete", sawdust can be substituted for sand/gravel/soil to make Sawdustcrete.)
BT, good point about spreading concrete. I've done the same with old leftover concrete bags (the mix). But there I drop it into my bucket, break it up, then spread it over wet or problematic areas - areas where there should be more gravel but just too cheap to buy it.
/ Gravel road: Filling potholes with concrete???? #5
On our dirt county road (there is some gravel in there if you get out a magnifying glass), one 'fix' for the potholes and erosion was to switch to a single Garbage company with advice to the driver(s) to NOT do hard braking. We all noticed that the 4 garbage haulers were all in a hurry and doing emergency stops at every driveway.
Now one provider with smooth braking is helping immensly. The brake hop on the truck'(s) double axle was the major cause of the hole digging. We still have some people doing burnouts as they leave their house, but this becomes obvious.
/ Gravel road: Filling potholes with concrete???? #6
I once installed about 2 miles of metal t posts and barbed wire around a lake property (owner wanted NO trespassing or drownings)
I dug a small 5-gallon bucket sized hole, hammered 6’ t posts into bottom of hole maybe a foot and dumped a dry 80lb bag of concrete mix in each hole. Still standing 35 years later :thumbsup: There was no convenient way to mix concrete and carry it to post holes (the whole job was in undergrowth and thick woods. Ground was soft and moist).
Generally, ground moisture will be absorbed by the dry mix and harden pretty good. Not at strong as a property mixed crete, but good enough for post ballast.
/ Gravel road: Filling potholes with concrete???? #7
That's gonna be a real pain to maintain. I hope you and the neighbor came to the agreement not to do that any more.
Tell him if he wants to fill holes to use the same type fill that is on the road. Gravel or crushed concrete would work fine and you could mix and grade either.
We did a road with crushed concrete that was maximum 3/4" and it has been awesome.
/ Gravel road: Filling potholes with concrete???? #8
Noooooooooooooo. Concrete filled potholes will only create new potholes around their perimeter and make it impossible to grade. If you're in the mood to buy a new attachment, a box blade with rippers will help disturb the hard bottom of the pothole and give you "new" material to work with.
/ Gravel road: Filling potholes with concrete???? #9
Putting concrete, or even dry cement in potholes, is a totally stupid idea.
You will have concrete rocks to deal with as they rip out when grading.
I'm starting to see a consensus....
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
2019 JCB 457 (A60462)
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
(20) 2.5cm X2M Ratchet Straps (A60463)
(20) 2.5cm X2M...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
