Battery temp sensor
/ Battery temp sensor #1
waveeater
Ford 555c
Newbie here. Is there anyway to bypass the battery temp sensor on a Ford 555C backhoe? The new alternator will not charge the battery and I was told it needed the sensor which is missing. I would like to bypass it to make sure the alternator is actually still good at least temporarily. Any help would be greatly appreciated.
Buy a 200 ohm resistor and install in the place of the sensor.
Do I just wire it in in the battery box where the sensor goes?
Awesome thank you so much for the help I will give this a shot.
I could not find a 200 ohm resistor but I did have a 150 so I put it on and it works; but it痴 charging the battery at 13.75 amps. do you think this will damage the battery?
/ Battery temp sensor #8
Do yu have a 50 ohm you can put in series with the 150 (or two 100 ohm resistors in series)?
JCT Skid Steer Dozer Blade (A64047)
JCT Skid Steer...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2016 Boxer 700HDX Compact Skid Steer (A63116)
2016 Boxer 700HDX...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2001 International 4700 Dump Truck (A64047)
2001 International...
2022 LIUGONG 925E EXCAVATOR (A63569)
2022 LIUGONG 925E...
