Replacment FEL Joystick cables?
/ Replacment FEL Joystick cables? #1
Tymanthius
Baton Rouge, LA
LS XG3135
I apparently managed to pop the boom up/down cable from my joystick to the manifold on LS XG3135 FEL.
Dealer is saying the cable is ~$85.
Anyone know of a better price?
/ Replacment FEL Joystick cables? #2
Can the cable be repaired? Havent looked at prices yet, but that seems a bit much for a cable.
/ Replacment FEL Joystick cables? #4
That is a relative bargain! A replacement cable for my John Deere show thrower discharge cap was $140!! I replaced it with a liner actuator.
Seriously, I doubt you will find one cheaper.
That is a relative bargain! A replacement cable for my John Deere show thrower discharge cap was $165!! I replaced it with a liner actuator.
Thanks for the info.
Any details on your replacement job? Does it work better, or lower failure rater, or what?
/ Replacment FEL Joystick cables? #6
It's fully encased, so it's probably beyond my skill to repair it. But replacement is fairly easy.
Mine isn't exactly like this, but close enough.
Pretty sure yours is not a Nimco or Indemor joystick. Doesn't your cable end thread into the joystick and have a jam nut?
No, it's not a Nimco. Yes, that describes it well.
/ Replacment FEL Joystick cables? #8
I documented the conversion here
The only down side is the liner actuator is on the slow side.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 TAKEUCHI TB240 EXCAVATOR (A64279)
2021 TAKEUCHI...
2005 Jeep Grand Cherokee SUV (A59231)
2005 Jeep Grand...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
SET OF (3) BOX MOUNTS (A63569)
SET OF (3) BOX...
