1920 tractor not turning over with good starter
   / 1920 tractor not turning over with good starter #11
Make sure the ground strap/neg cable is in good shape where it connects to the frame.
Put a socket on the nut at the front of the crankshaft.
Could not turn clockwise at all.
How much pressure should it take to turn with socket?
   / 1920 tractor not turning over with good starter #13
Are the hydraulics in neutral?
   / 1920 tractor not turning over with good starter #14
Block the clutch pedal down so it and the transmission are disengaged, if it still won't roll over with a breaker bar loosen all the belt driven components and try again. You might have a bound up accessory like a water pump or hydraulic unit. That would seem more likely to me, since it doesn't sound like the engine was giving any indications of distress when you shut it down last.
Oh boy, I'm getting in over my head here.
Will block clutch down and try again. Might be time to spend a lot of money at dealer. Gotta fix it. Not worth anything broke
No rush , its under cover, ill need to borrow a skid steer to pull it out and remove the bucket frame and backhoe and push onto trailer
I miss my workcrew (tractor)
flyerdan this is what I am also thinking.
Not water pump since its belt driven but the hydraulic pump could be the cause if its gear driven
   / 1920 tractor not turning over with good starter #17
I don't know your tractor, but to take the belt of to make sure the problem is not in the accessories is good advice.
But also make sure that the hydraulics are not dead locked. All levers should be in neutral. All the quick connects for loader or backhoe must be fully inserted. Check the manual if, or how you can bypass the hydraulics for loader or backhoe. Than try again.
   / 1920 tractor not turning over with good starter #18
I am just reading this problem and seeing everyone is talking about a possible ceased motor or something similar. I always look at smaller reasons it is not turning over. The first thing that comes to my mind is a bad ignition switch. When you use the switch to pre heat the igniters the switch gets very hot and internal corrosion occurs. There are 4 contact points inside the switch and if only one of them gets corroded the tractor wont start. A new ign. switch on ebay runs around $50. You might test the switch. If it is bad, the tractor can be started by jumping the starter solenoid. There are posts about how to do this but I can't remember the correct way to do it.
   / 1920 tractor not turning over with good starter #19
In the first post, he wrote: 12v check and tried to jump start. Same result.
Just thought I should update this thread
I had a Diesel mechanic come and take a look at the tractor.
First thing he checked was the ground from battery to engine, he said the connection was weak and I should clean the connection where it bolts to the block and recommended running a separate ground to the lower bolt holding starter.
That really was not why it wont start.
He tried turning the crank pulley with a large socket and it would not turn in either direction.
He said either a connecting rod or valve is broken In block.
Gonna look for a new tractor. HST since I do a lot of loader and forks work.
My brother has the same tractor, I guess he will get a parts tractor with loader and backhoe.
Thanks to all who posted helpful suggestions
Mike
Adams 8 Ton Weigh Hopper (A55314)
Adams 8 Ton Weigh...
LOT LOCATIONS (A56138)
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
1985 Miller Wildcat 350-D Welder (A55851)
1985 Miller...
2015 FORD F-550 SUPER DUTY (A55745)
2015 FORD F-550...
ALTEC CP12LF HYD (A52707)
ALTEC CP12LF HYD...
