'04 RTV 900 transmission problems, where would you begin?
   / '04 RTV 900 transmission problems, where would you begin? #1
Nomansland55
Bixby, Ok.
Ford 6640
I recently bought one knowing that the transmission was bad. I bought the work shop manual and checked the fluid pressure at the 3 ports, forward-reverse-neutral, and have absolutely no pressure from any of them. Any suggestions on where to start looking for the problem? Thanks
   / '04 RTV 900 transmission problems, where would you begin? #3
If you can understand it, the WSM has detailed descriptions with pictures in regards to how the system works. These are in 2-M1 thru 2-M20.
Also in 2-S series are troubleshooting diagrams that might help.
It's pretty complex but outlines all the processes that a Mechanic at your dealership would do to diagnose the problem.
I assume when you say you bought the WSM you are talking about the 479 page document?
   / '04 RTV 900 transmission problems, where would you begin? #4
no pressure at all could be due to a severely clogged filter, or broken pump/drive to it..
Yes on the WSM
   / '04 RTV 900 transmission problems, where would you begin? #6
Yes on the WSM
I'm certainly no expert and I struggle to follow the writings in the Manual. But, the answer to your problem is there. I'd start by reading "M" section thoroughly and try to grasp as much understanding of how it works that my pea size brain could absorb. Then the information in "S" section might make more sense.
It sure sounds like there's no pump output as suggested by radios1.
Found the problem. This is the bearing from the HST pump. Now all I have to do it find a new bearing and the 8 pistons because it scarred them up too.
https://www.tractorbynet.com/forums/attachment.php?attachmentid=645251&d=1584113913&thumb=1&stc=1
   / '04 RTV 900 transmission problems, where would you begin? #8
If the piston slipper and swash plate surfaces are not perfect you will not have a successful repair.
   / '04 RTV 900 transmission problems, where would you begin? #9
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
Land Honor Quick Attach Skid Steer Plate (A50515)
Land Honor Quick...
2014 Honda Accord (A50324)
2014 Honda Accord...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
2014 E.D. ETNYRE & CO CENTER DROP HOT OIL TANKER TRAILER (A47384)
2014 E.D. ETNYRE &...
