How do I start a Ford New Holland 545d?
   / How do I start a Ford New Holland 545d?
I brought the battery to a dealer and it passed a load test and the mechanic feels it should have enough guts to start the 545d. I think with the new solenoid and hooking up the condo's small pickup to jump the battery while cranking, I MAY get a little more success.
I hooked up the condo's Ford Ranger as a little extra battery support, I drained the old fuel and put fresh in and BOOOYA, she kicked right over. It sounds pretty darn good. I only ran it for about 2 minutes because I am not sure how the coolant level is. I will likely start a new thread tomorrow to ask some basic maint questions. Once I get one of the tires re-beaded, I will move it. Thanks guys for all your help. I am glad I found this site.
   / How do I start a Ford New Holland 545d? #33
Beautiful, glad to hear it!
   / How do I start a Ford New Holland 545d? #34
Glad you got your 545 Ford Tractor running.
Here is the manual no one seems to have:
Index of /Ford_545c_Manual
I came to this forum with a similar problem, but suspect the nuetral saftey switch in my transmission has stuck again
because I get nothing but dash lights when I turn the key and it ran good yesterday.
   / How do I start a Ford New Holland 545d? #35
I could be your fuel is bad or not getting to all injectors.
You can crack open the caps at the engine and see if a little fuel leaks out.
Did you check the fuel and water filters?
Oops I posted before reading all replies.
TIP: Always warm up a diesel before using or it turning off
   / How do I start a Ford New Holland 545d? #36
This is a TEN year old thread!
RRRoger (you) responded SIX years ago!
Nothing added in past SIX years!
You have now...read all replies ???
   / How do I start a Ford New Holland 545d? #37
Not to be out done by RRRoger...lol lol I heard an old farmers trick was to put some diesel in a spray bottle..remove the air filter and set the bottle to "mist" and give a diesel mist when trying to
start a tractor where the fuel system has be "compromised?" instead of bleeding. I bleed my injectors and when I was about ready to use the bottle i told my assistant (wife) let me try to start it one more time
CRAP I was looking forward to trying the spray bottle gig
   / How do I start a Ford New Holland 545d? #38
I LOVE your truck !!!!!
UNUSED JCT 84" HYD GRAPPLE BUCKET (A58376)
UNUSED JCT 84" HYD...
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
2014 Kia Optima Sedan (A56859)
2014 Kia Optima...
2010 TROXELL 130 BBL STEEL (A58214)
2010 TROXELL 130...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
