Help!! Can you identify this planter??? Maybe Cole?
   / Help!! Can you identify this planter??? Maybe Cole? #1
rellis73
Long 2610, Ford 8n, Farmall M, 2 Allis Chalmer Bs
I recently acquired a 3 point 2 row planter from my uncle. He used this planter in the late 70s and early 80s to plant corn and it has been in a shed ever since. I had just assumed since it is printed on the seed hoppers that this thing was a Cole. However, after cleanup and a few minor repairs I'm not so sure. This thing uses John Deere style plates and I was unaware of any Cole planters doing that. Does anyone have any idea what make/model this thing may be? Hopefully there will be pics attached to this post. Thanks in advance.
   / Help!! Can you identify this planter??? Maybe Cole? #2
Sweet little unit..!! Could be those Cole hoppers just happen to be the same size, as that unit used before. And those definitely aren't Cole style plates, at least that I've seen, and that was only 2 styles.
Personally, I'd be looking real close on the cast iron parts, for part numbers. Seed hopper bottom assy., seed drop foot/shoe, things like that. Then use Google to do a search on those part numbers. It may lead you to a parts list somewhere.
It looks a bit rusty, so I'd imagine the fasteners that may not twist off, if you need to take something apart, may need a good soaking with a penetrate. I got a recipe from this site more than several years back, of a 50/50 mix of ATF, and Acetone. I used about anything sold on the shelf, and used KROIL for years. This 50/50 mix even beat KROIL hands down. Mix it in a dish detergent bottle for a handy applicator, and, so the Acetone won't evaporate. I started off buying a quart of each, just to try it. After that was gone, I started buying it in gallons, so it's always on hand. You just have to try it, to believe it.
The application that sold me, was the apron adjusting eye bolts on an old manure spreader we had here. Extremely flaky, corroded rust from acid in the manure,and just being weathered. I started a few days before starring to work on it, and gave it 2-3 shots a day, every time I walked past it, before I planned to work on it. I hand wire brushed the flaky rust from the threads, and gave it another shot. Once I broke the double nut lock nuts apart, I literally spun the nuts off with my fingers. Sold me right there.
Thanks for the insight! I had not even considered looking for part numbers in the cast pieces and I will definitely check on that. I appreciate the reply back and if I'm able to figure something out I will post back and let you know.
Thanks again.
   / Help!! Can you identify this planter??? Maybe Cole? #4
View attachment 643779View attachment 643780View attachment 643781View attachment 643782View attachment 643783
Thanks again.
Any chance you found out what it was. I just acquired same planter and im trying to figure out what it is as well
2013 Chevrolet Traverse AWD SUV (A53424)
2013 Chevrolet...
UNUSED IRANCH WROUGHT IRON SITE FENCE (A57193)
UNUSED IRANCH...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
Food Truck - 1999 Chevrolet Blue Bird School Bus and Turnkey Food Truck Business Package (A57024)
Food Truck - 1999...
Mower King Brush Cutter (A53317)
Mower King Brush...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
