shaeff
- Joined
- Oct 27, 2015
- Messages
- 1,042
- Location
- Hudson Valley, NY
- Tractor
- MF Utility 35 Gasser, JLG LJ500
I recently acquired this little guy, haven't gotten a chance to work on it yet but figured I'd make a thread about it. Shouldn't need *too* much tinkering to get it going. I know it ran last year, and I did get it to "pop", albeit for just a few seconds. I'll post updates as I find time to mess with it.
I figured, since these are pretty uncommon, borderline rare, and there's not much information on them, that anyone else with info on them, if anybody has one they'd like to share, anything at all to do with the JLG LITTLE JOHN LJ500, post it in here. There used to be a Yahoo Group called [little_John_Rocks] LJ500, but it seems that Yahoo Groups are no longer in existence and it's email chain only. While it may not be a mighty skid steer, it's "useful as a pocket on a shirt" as I've read elsewhere.
Here's a link to the only two threads I could find on here about the LJ500:
arizonian needing help with a rare skid steer
LJ500 Little John 500 manual wanted
control valve squealing on stand up skid steer
And a touch of good information from one of the above threads:
I'll leave with this picture of when I first got it, had to lift it off with my MF35 Utility Loader, as it doesn't run yet:
Last but not least- Gordoninvt emailed me the manual for this machine. If anyone wants it, I'll be happy to share. PM me your email address and I can send it. I printed the entire file, then re-scanned it as a searchable document. The searchable document is too large to send via email. I may be able to put it in a zip folder and we could try that way but no guarantee. Otherwise, you can send me a small flash drive and I can just copy the file and send back. Whatever. It's 50.1MB.
This seems to be a very common problem with these machines.
#1 The Little John does NOT use "Hydraulic oil" for it's hydraulic supply. Rather it uses SAE 10w30. This was found by a member of my little_john_rocks yahoo group in the troubleshooting section of the manual I set him up with. It reccomends that if you have low forward back moving power to switch from the 10w30 to 10w40. I changed mine twice before finding out I was using the wrong oil.
#2 From my personal experience chain tension plays a role in power at the wheels. The manual shows proper deflection along the bottom most run of chain as being only 1/4" Since the chain changes direction so many times I am convinced it makes a huge difference if your chain is very loose. More power with both wheels turning at the same time rather than the chain binding.
#3 JLG sold to another company shortly after LJ was built and the new owners concentrated on the big lifts.
The company that does at least try to help is Manitex. So far no luck but they will know the machine.![]()
