Oil & Fuel 1740M Greasing Spindles
   / 1740M Greasing Spindles #1
567Chief
Central Virginia
Ford 2000 (1965) Ford 801 Power Master (1958) Farmall Super-A (1949) 1740M
So I recently bought a 1740M and upon comparing my tractor to the diagram in my owner’s manual could not find the two spindle zerks referenced. Can anyone confirm that grease is not required and they are protected with hydraulic fluid? I’m finding too many disconnects between my tractor and my owner’s manual. Massey publishing needs to step up their game.
   / 1740M Greasing Spindles #2
One zerk fitting. If you look at the bottom of the housing you’ll see a drain plug for changing the oil
This is a good site for you to view all the parts. Login
   / 1740M Greasing Spindles #3
I found grease nipple discrepancies in my JD 4105 Owner Manual too... a couple added (FWD/REV pedal) and a couple removed (front axle). So it's not just MF that doesn't update their already published manuals when a slight modification happens.
Yeah, it's irritating.
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
(4) LT265/75R16 USED TIRES (A58374)
(4) LT265/75R16...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
