Jimc295
Anyone have issues getting the rear axle to lock. Sometimes my locks fine and at other times it will not lock.
Mine seems to engage whenever I press it... And releases when I'm off the lever...
Dale
I'm not looking to alarm you or anything, hopefully I'm wrong, but that almost sound like there's a problem there, ie, the pin sheered off. You sure it's locking when you step on the lever?
Ok, do you dig 2 holes like that when NOT stepping on the differential?
If I know I need to engage the diff lock before pushing into a pile i will turn the steering left and right while driving slowly. This lines up the pin to it's slot.
If I need to engage when stuck, I do as others have mentioned. I put pressure on the lever then slowly depress the forward or reverse pedal to allow the hole to line up with the pin. It then slides in gently without any clunking or other 'bad' sounds.
EXACTLY............
Dale
