Storing a fuel transfer tank
/ Storing a fuel transfer tank #1
tractorcrazy
How do you guys store your fuel transfer tanks when not in use. Mine is a eighty eight gallon L shaped tank its kinda awkward to load and unload in the truck bed. I use my front end loader then put it in the back of the shed when not using it. I might go with something smaller easier to handle just wondering how other people deal with theres.thanks Rick
/ Storing a fuel transfer tank #2
I haven't done this with a fuel tank, just a lot of other heavy things that size, but you could mount it on casters. Easy to move around in a shop or whatever that way. Obviously that'll only work if you're storing it on hard surfaces and you'd have to make doubly sure to secure it well in the truck.
/ Storing a fuel transfer tank #3
I just put mine on a pallet.
/ Storing a fuel transfer tank #4
Same here 110 gal L shape tank I just strap it to a pallet and put it in the hay barn
That's a good idea putting it on a pallet. I have a homemade set of forks I can put a skidsteer quick attach on for my loader tractor. Put a couple straps around it and should be good to go .thanks for the idea. RICK
/ Storing a fuel transfer tank #6
Mine is mounted on a pallet too. Pallet sits on a dolly with wheels when in barn.
/ Storing a fuel transfer tank #7
Mine is a plastic 55gal drum. When stored I just pick it up and put it on the top shelf in my shed.
/ Storing a fuel transfer tank #8
this is exactly the way I stor snd use mine. I can wheel it towards tractor to use, and lift it off of wheel base to place in truck to refill as necessary.
/ Storing a fuel transfer tank #9
I store mine on a pallet I built so I could load it with my forks from the side and set it in the back of my truck. My tank is 57x20x19 and I wanted it supported under the entire tank not 48".
/ Storing a fuel transfer tank #10
Before I put fuel in mine, I turned it over and welded caster wheels to each corner. IT is never in storage, always has fuel and in use. I can roll it around as needed. Mostly it sets in one place, it has 20 feet of hose so I can reach my tractor without pulling into the storage area. I keep my fuel inside an enclosed and insulated building where it is away from any ignition source and sunlight. The temps dont fluctuate up and down rapidly and I have never had any condensate issues with it.
Whether you put it on a pallet with casters or just attach casters directly to it, being able to move it around by hand is very useful.
/ Storing a fuel transfer tank #11
I don't have much in the of concrete floors or aprons around here so castors are kind of iffy. I do have SSQA forks and this is my solution and I am really happy I finally did it after grunting around fifty gallon drums for so many dumb years.
/ Storing a fuel transfer tank #12
Stored outside in the sun, you better have a good water separator on it. Likely even keep some biocide in the tank to attack any microbes and algae that get in.
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2022 EZ-GO ELITE...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
Unused John Deere Service Advisor V3 Electronic Data Link (A64194)
Unused John Deere...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
