5740 dif lock lever
/ 5740 dif lock lever #41
I am convinced. I am going to order one.
Seems like the MMC 94135K32, 13.5lbs/in, .080 wire, .640 dia, 4.00 long has been tried and is sufficient. Do you think it will hold up long term, or will the lever start to "sag", and then be half in half out.
My inclination is to order the MMC 94135K33, 17lbs/in, .092 wire, .730 dia, 4.00 long one, as it will most certainly be better than what is there and will be a little stiffer than the lightest one. Do you guys think the lightest one is good?
Thoughts?
/ 5740 dif lock lever #42
Thoughts?
Only time will tell. The spring is stainless steel, so environmental conditions should not effect it. The lightest spring has a good feel, and still takes a little resistance to push down. But once the pedal is down, it takes little force to keep it there. When you remove your heel, is comes back up sharply. The springs are cheap, postage will be the same if you order one part number or both, so get both and try yourself! Philip.
/ 5740 dif lock lever #43
Yep and Thanks... I am really cheap too... As Alaskakubota says, the lightest one comes in a three pack... so 12 bucks for the pack plus shipping. The heavier ones are one per pack at 5.66 each plus shipping. If it is worth getting both, i should do it all at once. Not like a big decision... but then again, a dollar spent is a dollar that I don't have anymore, and it then turns into junk in a drawer. If this is the biggest decision I make all day, it won't be too bad of a day.
/ 5740 dif lock lever #44
I got the springs and put on 94135K32, 13.5lbs/in, .080 wire, .640 dia, 4.00 long.
What a difference.
If you have any doubts, just do it. It is worth the trouble.
Thanks for the suggestion.
/ 5740 dif lock lever #45
I know I am reviving an ancient thread but made this mod on my L3560 and it makes a world of difference. Had not seen it until it was linked to in another thread. Maybe someone else will notice it if its gets bumped to the top.
/ 5740 dif lock lever #46
Definitely going to try this. I'm guessing the lighter spring has held up fine???
thanks ahead of time for any updates to this thread.
/ 5740 dif lock lever #47
I am the one who did the original modification in December 2011. Everything has held up fine and have not touched a thing since the modification, works very well. Philip.
  • Good Post
Reactions: fc1
/ 5740 dif lock lever #48
Thoughts?
How about just keep eating cheeseburgers until you are heavy enough to hold the thing down? Worked for me!
/ 5740 dif lock lever #49
Talk about timely. I was cursing the lock last night, because my rubber boots wouldn't keep the rears locked while simultaneously trying to push the tractor backward with the bucket. I don't want to think about what it did to the gears in the rear end. I had been considering a bracket extension of rod and angle iron to fit over and clamp to the existing lever when "The Fred's" post boosted this to the top.
I just ordered a set of 3, and they supposedly will be delivered on Monday.
/ 5740 dif lock lever #50
I guess better late than never just did this on the L5240. Lot of difference in the springs. I always hated that strong spring. Good quarantine project. Thanks PHILIP8N for posting it.
/ 5740 dif lock lever #51
Assuming you went with the lighter model, I don’t suppose you’d want to sell/mail one of your extra springs to NY?
/ 5740 dif lock lever #52
Assuming you went with the lighter model, I don稚 suppose you壇 want to sell/mail one of your extra springs to NY?
I did go the lighter one.
McMaster was 12.76 for 3 + tax and shipping made it $22.19 total
I am not sure what shipping would cost me. Not sure it would save very much. We are trying to not leave the house. But I guess if the USPS would pick it up out of the mailbox then it may not be too bad. They would probably be cheapest shipping.
/ 5740 dif lock lever #53
I know I am reviving an old thread but I wanted to thank Philp8n. I ordered the spring like he did for my Grand L 5460. It worked like a charm. I did pay almost $24 for spring (actually 3 as that is how they are sold) but oh my what a difference. My differential lock actually works. Now if I had a pedal instead of a round rod I would be set. This is a terrible design on Kubota’s part. I looked at a couple of local places to try and find a spring that would but couldn’t find a suitable spring. It was worth every penny.
It’s ashame I had to modify my top of the line tractor to function almost as good as my former Mahindra 2615 which was a bare bones tractor but it had a differential lock pedal that didn’t require a ton of force to engage.
Members like Philip are what TBN a great resource.
/ 5740 dif lock lever #54
I am happy you found this old thread and are satisfied with the modification! Philip.
/ 5740 dif lock lever #55
Thank you for posting your modification. I changed the spring out this morning and used the differential lock several times today and was a huge improvement.
/ 5740 dif lock lever #56
I must be doing something wrong. When I put 94135k32 in, spring of the same spec except 8.45lb/in. ??? Pack of three $12.76
F-250 SuperDuty (A63689)
F-250 SuperDuty...
more info coming soon (A61569)
more info coming...
Frontier RC2060 5ft Rotary Cutter (A65640)
Frontier RC2060...
INSPECTION (A65583)
INSPECTION (A65583)
40ft Shipping Container (A65583)
40ft Shipping...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
