Back up cameras
/ Back up cameras #1
Spanky72
Ls xr4145
I lost my right eye in a car wreck a little over 4 years ago. Hooking up implements to my tractor has been frustrating to say the least. So after shelling out money for a new LS XR 4145 I decided to add a backup camera. I called camera source and ordered a 7" weather proof monitor and a hd infarred Sony camera. It's mounted looking down on the lift arms. You can definitely see to hook up, but it doesn't allow me to line up on the implements before I'm right on top of them. So I bought another camera (monitor will support you to 3). The second camera looks straight back and is perfect for lining up on the implements and when you get close just hit a button on the monitor and swap to the down facing camera. It has made my life so much easier. Also the back looking camera is great for driving on the highway!
/ Back up cameras #2
I feel it's my duty to inform you when you boast of improvements like this, photos and links are required. :)
I've had a rear facing camera on my tractor for a little while but haven't got much use from it until recently. I am supposed to wear a distance improvement of +250 but I rarely do. I can't clearly see the monitor without them though. I keep some +275 glasses in my pocket which is the minimum I require for reading. Driving or operating equipment my vision is clearer without glasses than it is with the reading strength. I recently came across some full lens +250 safety glasses and put a set in the storage compartment on my tractor. Now when I get on I take my readers out of my pocket and put on the safety glasses. With those I can see the camera monitor clearly and it helps a lot. Especially when I'm on the road which is seldom but happens from time to time.
Installing a second camera is a great idea.
I just used a cheap one but it's under a canopy and the tractor is kept under a shed.
/ Back up cameras
I'll try and take a few pics and figure out how to load them.
/ Back up cameras #5
I've had camera on my CUT for quite a while now.
I venture to say it won't be long before they are standard on most CUTs.
Makes marketing sense as for a mere few $'s (at cost) they can offer profitable options just the way all cors now have all those built ins.
/ Back up cameras #7
Great idea!! I'll bet it would work for a rear mounted snow blower, too.
YEP, that is why I mounted mine.
Contrary to their specs mine operates fine to the coldest of the coldest
I used magnets to mount both camera and display so that way if snagged they don't get damaged but simply flop over and dangle.
Definitely a worthwhile add on.
/ Back up cameras #8
I finally found an HD cam system on Amazon, it comes with two cams and a monitor - I'm going to install on my Bobcat E42 excavator. Frequently I work in very tight quarters and its impossible to see on the right side. Usually I can swing the house for visibility but not always.
/ Back up cameras #9
Here are a few upgrades I made earlier this year after I lost my 1742 in the flood That had only 80 hours on it (**** I loved that tractor) I replaced it with a 1755. I installed front and rear night vision cameras with the split screen that can handle up to 4 cameras. Then I also added A thermometer and humidity gauge and LED front rear and side work lights and dome light.View attachment 628817View attachment 628822View attachment 628818View attachment 628819View attachment 628820View attachment 62882120190722_195538.jpg20190722_174637.jpg20190722_210713.jpg
/ Back up cameras #11
Spanky72, would you mind posting a link to your source for the monitor and cameras?
/ Back up cameras
Agricultural Back-Up Cameras & Rear View Camera Kits
I called them and they knew exactly what I needed. Amazon is cheaper but I couldn't find a weather proof monitor there. These folks had it all. I didn't mind paying a few dollars more for getting exactly what I needed the first try. Good Customer service is worth something.
/ Back up cameras #13
Thanks, Spanky72! Ha, when you said you called "camera source", I thought you just meant you knew a guy. :laughing: Didn't realize it's the name of the company. Looks like a very good source for quality equipment. This would be for a buddy with a new cab tractor, so weatherproofing for the monitor is not as important. But I know he will want a good camera.
My setup on my cab tractor is one I installed 5 years ago for about $50 just for kicks, to see how useful it would be. It was inspired by 94BULLITT's epic thread https://www.tractorbynet.com/forums/customization/316927-backup-camera-50-a.html Not nearly the quality and resolution of what you have.
/ Back up cameras #14
I installed a cheap unit and so far am very pleased with it. Like PILOON, I use magnets so I can move the camera around. Makes SSQA hook ups easier, as well as using pallet forks and the tree/post puller. the monitor is in the cab so being weather proof was not necessary. Best $74 I spent.
Thinking about adding a rear camera as well.
/ Back up cameras
I had to have the weather proof monitor for my open station cab
/ Back up cameras #16
I bought this camera from Amazon. I am still in the process of hooking it up. I have mounted the front camera into the grill and welded a piece of mesh over it. I plan to mount the rear facing camera inside the rear window. The monitor will mounted on the tractor's dash. I am using this because it is hard to see the quick attach points and I think it will help when using the forks.
Mike
https://www.amazon.com/iStrong-Upgr...roof+Super+Night+Vision&qid=1574040772&sr=8-1
/ Back up cameras #17
I purchased a backup/rear view camera kit from Amazon and installed it in my Kubota. It came with two cameras a monitor and a lot of cable. At the present I'm only using one camera. Easy install. Saves a lot of neck craning. Less than $100. Definitely recommend buying one.
/ Back up cameras #18
Having done this 3-4 yrs back I have to agree. Saves my neck a whole lot.
Must agree however that when in close quarters I still look back just to be sure.
/ Back up cameras #19
Which one did you get? Link? How is the resolution?
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
UNUSED ATS POWER ATS-GAC40Y 40 GALLON (A64281)
UNUSED ATS POWER...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
