Post driver bit for rock breaker on excavator
   / Post driver bit for rock breaker on excavator #1
idahofarmboy
King George, VA
JD 3032E
I have a Kubota KX040-4 mini excavator with a rock breaker. I need to drive some posts into very hard soil. I started to wonder if someone sells a bit that can be installed in a hydraulic rock breaker to drive posts intro the ground. The bits are fairly easy to change.
I even thought about making my own and buying a spare rock breaker bit, cutting the end off flat, and then taking a pipe sleeve and welding it to the end of the bit to keep the flat end of the bit over the post and keep the post straight.
Has anyone ever done this? I know they make hydraulic post drivers, but I already have the rock breaker which should do the same thing with the right bit. I'd rather spend a couple hundred dollars instead of a few thousand.
Thanks
   / Post driver bit for rock breaker on excavator #2
The municipality I use to work for made something like this for driving sign posts. They said it worked well. I welded up the adapter for them.
Buy a new rock bit and cut the old one.
   / Post driver bit for rock breaker on excavator #3
You could also shrink-fit the pipe sleeve. A a welder once explained to me that welding a hardened shaft was not a good idea. He proved to be right.
How do you shrink fit? I've never done this before.
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
Bucket (A55973)
Bucket (A55973)
2019 GALYEAN...
2012 John Deere TX Gator Utility Cart (A56857)
2012 John Deere TX...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
2011 Kenworth T700 T/A Sleeper Cab Truck Tractor (A55973)
2011 Kenworth T700...
