case 450 dosser
/ case 450 dosser #1
pjlneebish
Kubota RTV-X1100C
I am loosing fluid from m/cyl for pedal steering . I need parts 72989,71129,71121,71131.
/ case 450 dosser #2
Is that an early model 450..?? Looking through the parts list on the Case Construction online parts catalog for the 450 (there were 2 versions) I see no matching part numbers for what you have listed. Are those part numbers from a hard copy parts book..??
If in fact it is an early 450, not a 450B or 450C, etc. as mentioned, there were two models of the, "straight 450 model". In that case, you'll need the serial number from your tractor to determine which of those you have.
I've attached a link below to the Case Construction site, with various models of the 450 crawler (amongst other 450 models of different equipment.) Look through the list, and determine what you have. Look for parts matching your numbers above, to OEM numbers. If OEM parts aren't still available, you can use the OEM number searching through a search engine such as Google, and find aftermarket parts.
10 years ago when working on my 480C backhoe brakes, I found some high quality aftermarket parts here: Remanufactured Transmissions, Torque Converters, Engines - Joseph Industries It was less expensive at the time, to buy complete newmaster cylinders through them, than just the kit to rebuild the originals. The originals were in pretty bad shape from rust corrosion, so I took a chance. I still have the hoe, and brake cylinders are still working as well, as when I put them on.
Hope this helps.
Official Case Construction Equipment Online Parts Store and Parts Look Up. Parts for Case Equipment and Construction Equipment. Parts Store for Case Wheel Loaders, Case Excavators, Case Skid Steers, Case Original Parts.
/ case 450 dosser #3
Try Brokentractor.com for case parts they have a large supply and the price is usually better than Case also. Next thing lots run them with out brakes in fact both the ones I have had never had brakes very long even after putting lots of money into them.
/ case 450 dosser #4
I agree, you can put a pile of money into the brakes and they won't last long...
I've never had brakes on my 450, and with the 450's hystat tranny, you really don't need them, as long as you pay attention to what you are doing.
SR
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2018 Chevrolet Cruze Passenger Car, VIN # 1G1BC5SM5J7145503 (A61165)
2018 Chevrolet...
2006 Ford Crown Victoria Sedan (A61569)
2006 Ford Crown...
UNUSED KJ 40'X20' STEEL CARPORT SHED (A62131)
UNUSED KJ 40'X20'...
2015 Kia Soul SUV (A61569)
2015 Kia Soul SUV...
