2015 RX 6620PC CEL
/ 2015 RX 6620PC CEL #1
PuJo
Member
Central Louisiana
2015 RX6620PS
Morning gentlemen,
The CEL light on my RX6620 is on and not sure what it means.
I read somewhere that any OBDII scan tool will be able to read the code associated with the CEL light, is this correct?
We lost our local dealer and the closest dealer is now 4 hours away so I have to fend for myself on this one.
Hope you guys can help me out!
Pujo
/ 2015 RX 6620PC CEL #2
From my knowledge, the dreaded cel light coming on is potentially related to a catastrophic failure of the DPF regen system. A sensor has detected, and hopefully wrongly, a fully plugged DFP filter, and is notifying the user of the need for DPF replacement. And that could be very expensive to replace.
Has your tractor been performing regens in a timely manner, and when has your last regen occured. Has your tractor been giving you any alerts during regens, that could be considered an early warning?? Refer to your owners manual on this specific issue.
Also, a fuel rich mixture caused by injector problems can plug the DPF very quickly, leading to the cel light coming on. Read and search on this forum for additional information regarding tractor regens, DPF plugging and the cel light.
If your tractor actually starts right now, I would encourage a manual regen immediately, and running at high RPM (2600 rpm) for 30 mins, to increase that exhaust temperature and burn out the carbon particulates in your DPF. Perhaps doing this may save you a future DPF replacement.
Since I have never actually experienced a plugged DPF and having a cel light coming on, my advice is limited.
Thanks for replying. I've been going over every connector and obvious things I can do myself.
I plugged in an OBDII code reader however, that did not work. I haven't had any issues with the tractor and regular regens have occurred over time while using the tractor.
No other signs of anything going wrong. I don't think the DPF is plugged as the tractor starts and revs up to approx 2500 rpm's.
I think I am experiencing a lack of power but can still operate the tractor in high gear @ 2200 RPM's. From what i've read, if this was a regen problem, I would not be able to get the rpm's up that high. Please correct me if I am wrong...
Thanks
I parked the tractor on level ground and ran it for approx 40 minutes at max throttle 2600 RPM's.
This made no difference with the current condition, I still sense a loss of power (limp) and the CEL light is still on.
I am still researching the issue, if someone would like to chime in please do!
Thanks!
Pujo
/ 2015 RX 6620PC CEL #5
Thanks!
Pujo
Pujo, What was the verdict of the fire you had back in 2016? https://www.tractorbynet.com/forums...-kioti-rx6620ps-2.html?highlight=#post4573506
Could you have some wiring damage left over thats just now acting up?
Could you have some wiring damage left over that's just now acting up?
The issue with the fire was apparently some kind of rodent nest said the dealer.
Not sure I agree however everything was replaced under warranty and haven't had any issues since.
That was actually my first thought however nothing obvious.
The dealer closed shop last year and no dealer within 200 miles in any direction.
/ 2015 RX 6620PC CEL #7
Well glad you encouraged a manual regen, having the tractor up to high RPM and with hot exhaust. That most likely means the CEL light is not related to a DPF emissions issue. Apparently the second most common cause of CEL light is..... bad diesel. Either water or some other contamination is being detected by your engine sensors, and that may also explain the reduced power of the engine.
I know it's a headache, but it maybe wise to drain the fuel tank at the fuel filter, and also drain the fuel filter of all fluids, keeping a watch for water. This is the time of the year to get water in the system. Prime the filter with new diesel, and reinstall. Fill the tank with new diesel, and hopefully that CEL light shuts off and you get full engine power back.
I will do that this morning and see what happens.
Thanks!
/ 2015 RX 6620PC CEL #9
There are hundreds of codes that can trip a CEL , just because it’s on doesn’t automatically mean it’s dpf related. The only way your going to know is having a scanner read the code. You can try clearing the code with just about any scanner, it won’t give you the code info but should recognize there is a code and clear it. I’ve done this a couple of times. There are different things the ecu will due depending on what codes are thrown, some will cause a high idle while others will cause a limp mode with a lower max rpm.
I agree and I don't think it's a dpf issue either. I called a local Mahindra dealer and they said they can work on it but can not honor the warranty.
So I loaded it up on the trailer and headed to the Mahindra delaer and now waiting to see wheat the issue may be.
/ 2015 RX 6620PC CEL #11
Really, they say they can read the codes? That would be great for me if they can. I have a friends brother in law that works for a local mahindra dealer I’ll have to talk to him. My closes dealer for kioti is 2 hours now.
Hope they get you fixed up, keep us posted.
Well, they said they can work on it. I did not specifically ask if they can read the codes.
The gentleman told me that their mechanic worked at the Kioti dealer before they closed up. I sure hope they can read the codes.
I will defiantly give them a call in the morning to find out the details. I will keep you all posted on the status.
-Pujo
/ 2015 RX 6620PC CEL #13
Seams like I remember Kioti helping customers with warranty work at local tractor repair shops. Might be worth a call to find out what they suggest as you dealer closed. Maybe they would reimburse some of the cost? :confused3:
Would you have a number?
/ 2015 RX 6620PC CEL #15
(877) 465-4684‬. M-F 8:00am to 5:00pm EST. Hope that helps!
Here is an update on the tractor.
I did bring it to the Mahindra dealer as they said their tech could diagnose and make the repairs as he use to work for Kioti.
Well, I picked up the tractor today and still the same issue. the CEL light is still on and operating at a reduced rate of power/torque. Mahindra said it may now be in "D" mode or something like that.
I guess its time to find a way to haul it 3 hours down the road to a Kioti dealer!!!
/ 2015 RX 6620PC CEL #18
I hate to hear that! Hopefully that dealer will be able to help. 73
I went to the Kioti dealer today and when they connected the computer to the tractor and cleared the codes, everything was fine...until.....
When the codes were cleared, the regen light started flashing. (park regen). The soot buildup was being listed at 200% and the tractor would never go into regen. It would idel high for a minute and then fail. With 140 hours on the tractor, I cannot see the unit being completely stopped up. It runs too good otherwise. So the dealer called Kioti and still no answer as to why it will not regen. There is 3 days left on the emission warranty so I sure hope its covered!
Cheers!
/ 2015 RX 6620PC CEL #20
PuJo, sorry to see the Kioti dealer code reading shows a fully 200% plugged DPF. Hopefully Kioti honors the emission warranty. The DPF is an expensive item to replace. I also think the DPF is a sealed unit, and cannot be manually cleaned out. A new DPF replacement required, and the computer emissions reset.
My CK4010 just did 418 hours today. I typically run my tractor at high rpm to always keep the exhaust hot and encourage automatic regens. It automatically regens like clockwork every 26 hours. When its a successful regen, you can both smell it and see minor smoke.
Best of success on the repair of your emissions system.
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
UNUSED WOLVERINE MAD-12-12D (A64281)
UNUSED WOLVERINE...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
(2) UNUSED 16.9-24 TIRES ONLY (A64280)
(2) UNUSED 16.9-24...
Challenger MT800/MT800B Series Tractor Service and Parts Manuals (A63117)
Challenger...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
