What do you wish you had from the day your tractor arrived?
   / What do you wish you had from the day your tractor arrived? #61
Wish I would have had dealer widen back tires before I took it home. Also wish I would have gotten a tractor with more ground clearance
   / What do you wish you had from the day your tractor arrived? #62
Have you been able to widen the tires since bringing it home?
   / What do you wish you had from the day your tractor arrived? #63
No. Not sure I want to try moving a rear tractor tire and dealership charges $105/hr
   / What do you wish you had from the day your tractor arrived? #64
Backhoe, SSQA with Remote.
   / What do you wish you had from the day your tractor arrived? #65
Are they loaded? Mine are not, I widened them last year and am glad that I did.
   / What do you wish you had from the day your tractor arrived? #66
Yes, loaded
   / What do you wish you had from the day your tractor arrived? #68
There were a number of attachments that I wanted and I have some of them now - mostly used.
What I overlooked because I did not appreciate its importance, was a 3Pt counterweight. I bought a used snowblower which is heavy and hangs out 4', but I cannot go in the woods with it.
   / What do you wish you had from the day your tractor arrived? #69
Just like the title asks? What parts, attachments, tools, or anything else did you overlook when you first recieved your tractor?
I'm buying in the next two or three months, most likely a l3901 package deal with rotary cutter, and box blade. Been using tractors for a bit more than a decade and ready to step into something modern. Will use mostly on flat land for pasture cutting and gravel drive maintenance
Thanks in advance!
Easy answer...NO PAYMENT BOOK
   / What do you wish you had from the day your tractor arrived? #70
another new tractor to replace my other one ;-) you can never have enough tractors can you ?
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
2023 Kubota L2502DT (A53317)
2023 Kubota...
Utility Cart (A55851)
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
PALLET OF KUBOTA L3902 HOOD, DASH (A57192)
PALLET OF KUBOTA...
UNUSED IRANCH 14' BI-PARTING GATE (DAMAGED) (A57193)
UNUSED IRANCH 14'...
