What do you do with your Instant Pot you cant do with a crock pot?
   / What do you do with your Instant Pot you cant do with a crock pot? #511
^^^^ the IP has to go through a warm up, then cook, then slowly release the pressure to avoid boiling... so I would not say minutes.
It seems to me cooking a whole chicken in the oven as an example is only maybe 20% slower.
The single pot concept of adding veggies, and less cleanup is a big advantage to me of the IP. Plus the flavor. Just not so much the time difference in cooking.
   / What do you do with your Instant Pot you cant do with a crock pot? #513
Meat is more tender in the IP.
My wife is a hardcore crock pot holdout, but I’m making inroads. The last pork chops she did in the oven were rather chewy. I need to do some in the IP.
   / What do you do with your Instant Pot you cant do with a crock pot? #515
Yep buckeye my wife is the same . . . we just received the IP (I ordered it :eek:) . . . it's a slow cooker too.
   / What do you do with your Instant Pot you cant do with a crock pot? #516
I made this tuna casserole last night but being low on groceries I had to improvise a little. No chicken stock so used Beef stock, no cream of celery so used two cans of cream of mushroom. No egg noodles so used a box of Rotini. (use anywhere from 3.5 to 4 cups of broth with Rotini and you should be fine. Due to no celery in fridge I also doubled up on the mushrooms. Also don't understand the pyrex bowl requirement. Used a stainless mixing bowl.
Even with these changes it turned out delicious. Even my picky wife loved it.
Instant Pot Tuna Casserole in less than 3 minutes | The Foodie Eats
   / What do you do with your Instant Pot you cant do with a crock pot? #517
Looks good!!
   / What do you do with your Instant Pot you cant do with a crock pot? #518
the dog photobombed you. :)
Exactly. I cannot go into the kitchen without one of the canine kitchen supervisors overseeing everything I do. :D
   / What do you do with your Instant Pot you cant do with a crock pot? #519
With all those substitutions and it turning out so good, you should publish it. :licking:
2014 Dodge 5500 4X4 Bucket Truck (A51039)
2014 Dodge 5500...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
1982 LeeBoy Motor Grader (A51039)
1982 LeeBoy Motor...
