Help choosing indoor security camera
   / Help choosing indoor security camera #21
I vote for Wyze also. We bought 2 cameras about a year ago to put in my parents apartment at the assisted living home where they lived. It was under $100 for both cameras and only needed power and wifi. They have served us well and I still use them to check on mom. Dad passed away last August.
One feature I like with the Wyze (others probably have this feature too) is that I can share access to the cameras with anyone I wish. So, my 2 sisters can check in on mom at any time. Since I was the original person to set up the cameras, I'm the only one who can look back to see what has been recorded. I do use this often. Others who I give access to can only view live shots.
   / Help choosing indoor security camera #22
Wyze is a great deal. Simple, great resolution, onboard storage and rather low bandwidth usage. Oh and the best part, about $30 bucks!
   / Help choosing indoor security camera #23
My upload speeds vary between .6 to .9. As far as I can tell my wyzecam uploads okay. I pulled the sd card out and just use the cloud clips.
As far as security is concerned if you have a decent password on your network you should be safe. I don't aim any cameras at anything I need protected anyway.
We're at ten days or less, and my wife's getting more and more fussy in getting everything ready. Even bought new hemostats today!!!
My wife just took this picture of Kami.
   / Help choosing indoor security camera #25
I see that most of these units require 2 Mbit/sec upload speed. I am only able to get .75. Has anyone been able to view their camera remotely with slow dsl upload?
My rural grandfathered internet is supposed to be 1 Mbit but I RARELY get that, usually it's about 0.6 Mbit.
Wyze has a feature that let's you group cams and view up to 4 cams live on 1 screen.
I've found I can reliably have 3, sometimes 4 in a group and view the group. More than 4 in one group on the rural net at a time and one will "hang". So I run them in several groups, 4 for the front, 4 for the back, others for testing, watching the sump pump etc.
My system in Virginia is on a relatively high speed net (I sometimes get 20Mbit/sec UP), I usually run all 7 cams in a group with no problem except the native app puts it on 2 screens.
Any camera that REQUIRES the internet to operate gets zero stars in my books. If your idea of security is leaving your keys in the door, the door wide open and your wallet on the doorstep then go for it.
I just picked up a cheap IP camera from amazon. As soon as you turn it on it tries to make at least half a dozen back door two way connections to multiple servers in mainland China that bypass your firewall. Block internet access and you cant use your camera on your local area network. I sent it back to Mao.
There are plenty of expensive security cams that will fill your needs and don't require internet. Jut remember if you have a modern cell phone all that data is trackable and collectable by NSA whenever it's turned on.
Thanks to the recommendations on here, we looked at the Wyze Cam on youtube and decided to give it a try. For $25, it seems like a worthwhile gamble to see if it works like everyone says it does. It's scheduled to be delivered Wednesday, and I'm sure my wife will have it working ten minutes after she gets home and opens the box!!!!
https://www.amazon.com/gp/product/B076H3SRXG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Well - -since you bought it -here's a few random pointers
Get a good 32MB SD card, I use Samsung
Time lapse - kind of weird - It's limited to about a month. So for example I like time lapse. I can run a time lapse with SD quality scenes taken once every 3 seconds for 12 hours and it creates about a 1GB file, no problem. That's about 15,000 scenes. But I can't run 15,000 scenes taking 1 frame an hour to document seasonal change. There also seems to be about a 2GB limit on file size.
They come out with frequent updates and new features, that may require loading new firmware or a new app. DON'T automatically load the new stuff. I'm a Beta tester for both hardware and software. I've spent countless hours reloading working versions. Often they break some minor (to them) feature in an upgrade. They seem to be a relatively small firm and rely heavily on us beta testers. But they treat us like clowder of cats.
If you want to run a camera "outside" they are pretty hardy. I've posted here about using them as backup cams and FEL cams and I can run them off my phone as a hotspot..
I finally found the specs for the Wyze Cam on their site, indicating that it requires a minimum 1.0 Mbps upload. They sure make it hard to find that spec. I guess I'm a little too far out in the sticks and don't have internet that fast so I'll have to pass unless somebody else has been able to use it with ADSL. I'm afraid it would hog all of my upload and screw up my network. Maybe in about a hundred years faster internet will be available for me.
Like I wrote, you can probably run several, just keep an eye on them. One time they did an upgrade to the Beta and all of a sudden it defaulted to my cell phone data plan and I used something like 200Mb in a few hours. We caught it in Beta and they fixed it.
Buy one from Home Depot, try it out, return if it doesn't work for you.
   / Help choosing indoor security camera #26
Thanks, I've been working on the whelping pen, or nesting box, for awhile now. I should be done this weekend, which is cutting it close.
What breed is Guinevere?
She is a Schipperke.
   / Help choosing indoor security camera #27
I vote for Wyze also, My bride and I are enjoying a short break in a warm climate and I can watch my driveway, home and shed. Good point earlier about the sump pump, not a lot of concern this time of year for me though. I have a few, indoor models are in the outdoors and have worked flawlessly, they are well protected from the elements. I order direct from Wyze and they are $19.95, I buy their sd cards as well, I don’t recall the brand.
I also have Canary brand, they work well but are $60.00. Bottom line, I have some peace of mind while away.
I had to google the breed. Thanks, I love learning about other breeds. Guess that's why we enjoyed watching Westminster the last three days!!!!
   / Help choosing indoor security camera #29
Amazon.com : Wyze Cam 1:Dp HD Indoor Wireless Smart Home Camera with Night Vision, 2-Way Audio, Works with Alexa & the Google Assistant, One Pack, White - WYZEC2 : Camera & Photo
Keep in mind you are recording video inside your home that will be pushed out to the internet. Some are OK with that, some not.
   / Help choosing indoor security camera #30
Amazon.com : Wyze Cam 18p HD Indoor Wireless Smart Home Camera with Night Vision, 2-Way Audio, Works with Alexa & the Google Assistant, One Pack, White - WYZEC2 : Camera & Photo
Duplicate
We love putting everything out on the interenet. Kind of why I'm on TBN and FB.
Everything we video will end up on Facebook!!!! The more people that know about the puppies, the more interest there is in them, the more choices we will have in finding them the best home possible.
I'm making the whelping box as fancy as I can so everyone that sees our video and pictures understands that we will do everything and anything for our dogs.
If there isn't a line of people wanting to pay us thousands of dollars for each puppy, that means we haven't posted enough pictures and videos!!!!
   / Help choosing indoor security camera #32
Eddie I hope you can share your experience with the cameras
Can you link the video of the pups here
Thanks
   / Help choosing indoor security camera #33
Did you see the Equifax Data Breach thread? Pretty sure Puppy Video's are low on the hacker's list.
   / Help choosing indoor security camera #34
We also watched the Westminster Dog Show. Finest looking dogs on the planet. I was hoping to see one of your Okita's there. Maybe soon?
I've owned probably every "dangerous" dog on the list, in the past. Now we've evolved to small terriers. Not sure I could control an Okita these days, but they sure are beautiful animals. Keep up the good work.
   / Help choosing indoor security camera #35
The risk is low, but that does not mean it is not there.
When his wife handles the puppies on video, will she have a diamond wedding ring on? Hmmm. In the background, might there be a set of valuable cut glass pieces, or a rifle leaned up in the corner?
A famous scam was when people were wanting to sell guns, or buy accessories for them, or other valuables. They took a photo of the gun, or part, or item using their camera phone, then uploaded that to Craigslist for their ad. What they didn't realize is the photo included the embedded GPS coordinates where the photo was taken-- courtesy of the "location" feature in many phones.
Criminals would then target the house or area where the photo was taken. Using Google Earth, they could even see aerial imagery to plan their entry and exit.
So, is all of this overly paranoid? Or merely a caution to be careful. As I first wrote, some are comfortable with video from their homes being pushed out to the public Internet, and some are not.
There where only 4 Akita's at Westminster this year, which was noticeably low. Billy Jean won breed, and she was the only female there. We've never competed against her, and she is the number one ranked female Akita in the country. We're number 3 female. I'm not sure if we could beat her or not, but I'm know that we can beat the other three that where there since we have in the past. Currently our boy is ranked number 9 in the country and our girl is was number 12 when she last showed.
The top five in every breed get invited to Westminster. Then if you are a Champion, you can enter if you want. One day we'll go, we would prefer to be invited, but to become a top five dog, you have to compete almost every weekend to get more points then anybody else. We try to get one of our dogs to a show once a month, but that doesn't always happen. We usually win Best of Breed with either of our dogs, and we only go to the bigger shows. It's super easy to win Best of Breed at a small show, but some of those shows don't even give you one point, most are just a single point. We want to win 4 or 5 points in a show, which means there has to be a lot of Champions to compete against. Everyone has their own philosophy on how to show, ours is to win big, or not bother.
I posted this on FB for our Akita friends to see.
We went to the Repro Vet in Nacogdoches the other day for xrays of the puppies. He counted 7. Since there are so many, we are going to do a C Section so there isn't any risk of losing a puppy. A huge concern for us is if one or two get stuck inside and she is too tired to push them out, or just isn't able to. Then we have to do an emergency C Section, which means loader her and the puppies up, taking all of them to the Emergency Vet Hospital, which is half an hour away, or going all the way to the Repro Vet, which is over an hour away. Then take the risk that the surgery is successful, and the uterus isn't damaged. It's very common for these emergency surgeries to result in making her sterile and never able to have puppies again.
We will find out Monday when he wants to do the C Section.
Since the camera works so well, we bought another, and will probably buy two more when the puppies get here.
Thank you for everyone that recommended the WYZE Cam, it's proven to be better then we had hope for at a very reasonable price!!!
   / Help choosing indoor security camera #38
I am looking for a security camera. One requirement for me is that the camera does NOT upload to a cloud somewhere. Anybody have any suggestions? I was told with the WYZE cameras, uploading to the cloud was a requirement in order to have access to the images on your phone.
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
flatbed trailer 24ft (A56857)
flatbed trailer...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
