Reviving a flooded CK35
/ Reviving a flooded CK35 #1
KyleB83
Anahuac, TX
John Deere 410C Gehl 303 Mini, Bobcat T650, Kioti CK 35, Komatsu D53-16
My father in law has a CK35 that was under water.. COMPLETELY under water.. I need something to do on my off days that makes me want to cuss and pull out more of my hair, so I decided to take a crack at seeing about reviving this thing.
Hopes aren't very high since its been more than a few months, but at least it doesn't cost anything to take stuff apart right?
The last time I was at his property, I did toss a battery in it, just to see if the engine would turn over.. Lets just hope it needs a starter since that didn't happen.
Im obviously going to check/drain/change the oil and filter, but what else would I need to try before attempting to turn the engine over? I was going to pull the starter off and see if I can turn it by hand with a big pry bar and make a decision from there before I even mess with the oil. If it is locked up, is there any of these magic oils at the local auto parts store that would be worth a try?
Im pretty sure this thing is going to be permanent yard art, but it's at least worth the time it takes to yank the starter to see right?!
/ Reviving a flooded CK35 #2
If it ran once it will run again. Just depends on how much time and money you want to spend.
How far under water? Over the exhaust or in 3 or 4 feet? I would not try turning over with the starter to begin with. Use a wrench on the main pulley bolt. So you can go slow.
If it is frozen up, remove the head and fill cylinder with motor oil. Allow it to soak, then use a block of wood and hammer to drive on top of the pistons. It will free up.
Drain all fluids including fuel tank. Make sure all water is out of the system and put fresh fluids in. Then start trying to get it running.
it was completely submerged over the hood.. off the top of my head, I am not sure where the exhaust is on his tractor. It wasn't running at the time, which may help, but it was still a submarine
/ Reviving a flooded CK35 #4
Just take your time and think it through. Most likely you will need to pull the head. After you free the engine, make sure to get all the oil of the top of the cylinder before trying to start the tractor. Hopefully no water got into the injector pump.
Keep us updated on progress and take pictures along the way. Will be interesting and helpful for others that find themselves in this situation.
/ Reviving a flooded CK35 #6
I lived in Houston for 5 years, and saw many cars and diesel trucks under water to roof top level. Except for the leather interiors, most of the engines came out just fine.
Just dont start anything for 5 days after the vehicle was first pulled out, to give the engine time to dry out.
Fully drain the fuel tank at the fuel filter, as this is lowest point of the fuel system. Fully replace the fuel filter and prime it (fill it) with diesel before installing. Connect fuel line from fuel tank and fill with diesel.
Check starter electrical contacts for corrosion and also replace starter if needed. Clean out the ignition switch with WD40 and then try to give the tractor a start. Hopefully it starts, and just let it run for 30 minutes to further dry out the engine compartment.
Good Luck.
/ Reviving a flooded CK35 #7
First remove loader if it has one. Make sure to pull all 3 glow plugs before trying to turn it over if you don't you will hydro lock a cylinder and could bend one of the connecting rods. Once you have drained all the fluids and put in fresh pull glowplugs and turn over with the starter until no more moisture comes out. After that put new diesel in prime the injection system put glowplugs back in and see if it will fire. once it is running operate everything for a few mins and then shut down and change all the fluids again while they are still warm. everything will probably be quite frothy so you will need to let it drain a couple of days. After that put all new fluids in again and then run it up to operating temp for a couple of hrs and check for frothy oil and hyd fluid if none then good to go if still frothy then would suggest changing all the fluids again.
/ Reviving a flooded CK35 #8
This is what I think. First drain the tank and get all the fuel out, up to the fuel filter. Than get the air filter out. Than drain the engine oil to get the crank case empty. Since it has been a few months, I think there will be no water left on top of the pistons, but there might be some water left in the intake. Take the glow plugs out. Try to turn the engine over by hand a few times. If that succeeds, put a few drops of engine oil in each of the cylinders. Take the starter off and take it apart, take pictures, clean, grease and put together, than bench test starter. (you might have to replace the solenoid) Use a new fuel filter, let new diesel fuel feed to the filter before connecting the fuel line to the filter, to get clean fuel in the system. (very important)
Put the starter back and try. If the engine turns over, and nothing blows out of the glow plug openings anymore (other than atomized diesel), put the glow plugs back in and try starting. If it starts, run it till warmed up. Than change engine oil and filters again, and take care of the rest of the tractor.
Better still, ship it off to me :)
/ Reviving a flooded CK35 #9
It shouldn't be too bad to get it going;
I'm assuming that this is a hydrostatic drive tractor.
I would;
1) pull the glow plugs
2) pour a bit of atf blended with acetone 50/50 into each cylinder, however much fits in
3) start draining all the oils engine and transmission, front axle dif and drop boxes
4) drain the fuel tank and system
5) pull the starter disassemble and clean it maybe even give it new brushes and lube the bearings
6) fill the rear end and transmission 3/4 or more full of diesel fuel, also the front axle drops and diff
7) the engine would be optional but I'd give it a couple of gallons also
8) roll the tractor back and forth several feet several times, vigorously a few times, could even rig a tow bar from the drawbar to a truck;
want that diesel to slosh and splash all around in those cases.
9) if that engine has a bleeder valve on the injection pump open that install a new fuel filter, then try and push fuel into and thru that pump,
if you can get fuel to and thru the injection pump ( or is this an electric common rail system)
10) now I would try and roll the engine over preferably with a wrench on the front balancer bolt
11) if she will turn over your almost ready to go
12) dump the diesel out of everything
13) fill everything with the proper fluids
14) button everything up
15) start it up
16) after she starts and is running move her around get all the fluids circulating and warmed up
17) if she sounds decent and moves
18) drain and replace all the fluids again
19) enjoy
/ Reviving a flooded CK35 #10
I would;
2) pour a bit of ATF blended with acetone 50/50 into each cylinder, however much fits in
15) start it up
19) enjoy
That is an EXCELLENT answer!
/ Reviving a flooded CK35 #11
Think all the electrical connections should be pulled apart cleaned, greased & put back together. Also if the tractor has a computer (don’t know if it does or not) will it be ruined & need to be replaced? Would also think the fuse panel needs to be addressed. What about the alternator? Good luck & be patient.
wow, talk about some knowledge from you guys!!
I just downloaded and printed the service manual on it, and will start messing with it tomorrow, depending on the weather.
The downfall is that the front loader is attached, and getting it off may be more of a pain than I want to deal with. Especially by hand lol
If I can't get the engine to turn over by hand, I will try the ATF, but nothing else would really matter if it is completely seized.
/ Reviving a flooded CK35 #13
Was the engine running when it went swimming? If it was, check for bent/broken rods $$$ before you dig too deep.
/ Reviving a flooded CK35 #14
I have freed many engines over the years with a shop hammer and a block of wood. I would not be afraid of that part at all. The advice others have given you is right on time. Once you get it free and fluids replaced, I would run her and decide where to go from there.
It's not as bad as you might think. Sometimes it will run like a top with no issue at all.
/ Reviving a flooded CK35 #15
I would;
15) start it up
19) enjoy
Follow this list!
/ Reviving a flooded CK35 #16
Wiring was my issue. Battery connected underwater for days meant massive corrosion to already bad wiring. The guy that bought it from me did get it running though. I was able to save my lawn mower.
Well, it definitely has no room to work with the loader attached.
I guess step 1 now becomes finding a way to get it off
/ Reviving a flooded CK35 #18
Keep us in the loop! Interesting thread.
/ Reviving a flooded CK35 #19
If you have another tractor available use it for a hydraulic source to manipulate the loader,
once the loader is clear pull the tractor back out of the way.
The stock hoses likely will be too short so you will need 4 extension hoses and coupler sets.
It can be done with a loader or backhoe to lift and carry the loader but it is not easy.
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
(INOP) 2023 CRATOS CMX18 ELECTRIC EXCAVATOR (A62129)
(INOP) 2023 CRATOS...
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2019 FORD F-150 STX CREW CAB TRUCK (A59823)
2019 FORD F-150...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
