PHL Area - JD4410 Service/Repair
   / PHL Area - JD4410 Service/Repair #1
cshoem286
2002 John Deere 4410
The JD4410 tractor will start/run but not move. Need assistance getting the tractor mobile to get it serviced. Anyone know of anyone who provides this service?
   / PHL Area - JD4410 Service/Repair #2
Did you look for jd dealers around the area
   / PHL Area - JD4410 Service/Repair #3
Tell us a bit about what led up to this "not move" problem. Must be some history of when it last ran, and what you were doing with it then.. might be can get some good advice from the many members here.. and save that trip.
As to "who provides that service" question, some local area info will help answer that..
Is it HST or PowerReverser tranny?
YES, was hoping to avoid them if possible for the initial 'GET UP AND MOVING PART' .... very expensive.
On the history .... it is stored outdoor and went through most of the summer. Fired up, but the backhoe stopped working so I parked till I could get a service date. When I got the date, went to start and move ... would not move. SORRY but that is all I have!
On the area ... I am in Schwenksville, PA 19473
Not sure ... I know it is a JD4410. I will look for the other details tomorrow. The rush is only cause I got the house under contract, so need to get moving on this item so I can ship to Pittsburgh.
--- Chris
   / PHL Area - JD4410 Service/Repair #6
--- Chris
If you want the tractor in Pittsburgh why not just buy a 7000 GVW trailer, and tow it there.
As long as the wheels turn, you can pull it up on a trailer with a come-a-long.
Having it fixed at your destination would give you some recourse if the fix did not turn out well, rather than being 100's of miles away from the shop that repaired it.
You could also just rent a trailer instead.
   / PHL Area - JD4410 Service/Repair #7
Perkiomenville, PA has a dealer 9 minutes to the North. Have you asked what they would charge to have someone come and start your 4410 ?
   / PHL Area - JD4410 Service/Repair #8
Did you look at the obvious? Is the 3 speed trans shifter in gear on the left side of the seat? Can get knocked into neutral.
On the right side fender, is the yellow light flashing any codes?
2 Warehouse Forks (A55787)
2 Warehouse Forks...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56435)
LIKE NEW 2023...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
COPPER POT & COIL (A58374)
COPPER POT & COIL...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2019 Freightliner M2 106 Flatbed Hauler Truck (A55973)
2019 Freightliner...
