   / Share Pics of People Hauling or Towing Something Wrong #11,922
That's a pretty small box for a full sized pick up.
It’s overloaded as it is. What use would a bigger one be? Have I ever mentioned before that I hate regular bed pickups?
   / Share Pics of People Hauling or Towing Something Wrong #11,923
It痴 overloaded as it is. What use would a bigger one be? Have I ever mentioned before that I hate regular bed pickups?
YES you have maybe once before....:D
   / Share Pics of People Hauling or Towing Something Wrong #11,924
Here’s a building I hauled off a while back. With a regular bed pickup I could have made 25 trips, totaled the bed, knocked the back window out and unloaded everything by hand. What’s not to love about that? IMG_8016.JPG
   / Share Pics of People Hauling or Towing Something Wrong #11,925
Here’s a building I hauled off a while back. With a regular bed pickup I could have made 25 trips, totaled the bed, knocked the back window out and unloaded everything by hand. What’s not to love about that? View attachment 639642
Yet it doesn't make sense to buy a truck which is too big for my everyday needs, on the outside chance I may get someday get the urge to haul off a building.
   / Share Pics of People Hauling or Towing Something Wrong #11,926
I don’t daily drive the 6500. I used to dd my ton dump but I don’t do that anymore either.
   / Share Pics of People Hauling or Towing Something Wrong #11,927
Here痴 a building I hauled off a while back. With a regular bed pickup I could have made 25 trips, totaled the bed, knocked the back window out and unloaded everything by hand. What痴 not to love about that? View attachment 639642
I would love to have a truck able to haul that off in a few trips :thumbsup:
   / Share Pics of People Hauling or Towing Something Wrong #11,928
A few pages back someone was lamenting that there were only 4 corner tiedowns in the pickup box, I had the same problem. I liked the hooks on my Datsun, but not the way they had a tendency to hook clothing when working over the side. I built some rails for the side of my Toyota with half chain links, contoured to the body lines so they won't hook you. About an inch of the inside angle iron was cut off, I welded studs where it goes through the box and drilled the cut off section so that the bed is sandwiched between 3/16" strips, so it won't distort if you use a come-a-long on it. Bolted on from the bottom so there are no bolt heads on top, the four bigger holes at the front and back have nuts on the backing strip so a ladder rack or other future thing can be added easily. The chain links work great for bungee hooks, and rope cleats.
   / Share Pics of People Hauling or Towing Something Wrong #11,929
I would too, but don't have enough work to justify the cost and it could never replace my pickup.
   / Share Pics of People Hauling or Towing Something Wrong #11,930
You couldn’t haul 10 tons at a time but what would you loose with a dump bed that a regular bed does better?
Jack Daniels Toy Truck (A55853)
Jack Daniels Toy...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
1837 (A51248)
1837 (A51248)
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
