Probably stick with the JD 2 series.
/ Probably stick with the JD 2 series. #1
RalphVa
Super Member
Charlottesville, VA, USA
JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
With the driveshaft Ujoint problem on my first JD (a 4010) and a lemon of a 1025R, I'd gone sour on JDs, particularly after finding out that they have not solved their Ujoint problem.
Been researching Kubotas, as it's really the only other tractor outfit around here. Was very interested in a B2301. I put together a spreadsheet comparing it to the 2025R, and the B2301 won out on the spreadsheet comparison.
However, found a B2301 owner with the same throttle lack of hold that I had on the 1025R. Another perennial Kubota problem seems to be their hydraulic couplings. A friend of mine with one has leaking couplings, and others have reported them, some fairly early.
Kubota engines do not seem to be as smooth as Yanmars either, even though the 3 JDs I've owned all have had the shudder and shake startups when cold (like 1973 and 1983 Benzes we've owned) vs. very smooth on our VW TDI and Isuzu diesel generator driver. At speed, they're smooth. 3,000 rpm is smooth. Normally only run the 2025R to about 2,500 rpm max because I simply do not need all its available hp. The 18.5 that I had with the 4010 was completely adequate for bush hog, chipper/shredder and snow moving work.
Turns out the B2301 has also a weird thing in its oil pan: 2 drain plugs. Would't be able to use my oil extractor like I've done on the 3 JDs.
Cannot beat the absolutely goof proof working of the FEL on the 2025R (vs. the 1025R's being a disgrace). The 4010's was equally as goof proof, just slow.
Gobs of 3ph adjustment holes on the 2025R vs. seemingly not too many on the B. Finally found the hole combo that I use for both the bush hog (to get it nice and high) and the MacKissic chipper/shredder.
Guess I'm stuck with green. They're, by far, the closest dealership but actually moved to the old Volvo site and has a huge increase in stock. My sales guy mounted the 1025R's tool box onto the 2025R where it is on the 1025R (behind the seat).
Guess I'll actually change out the coolant this year (3rd). Think JD and Kubota's recommendation of coolant change ever 2 years is severely old stuff what with cars (and the Isuzu) going 10 years.
Going 200 hours on those sorry Ujoints. I just have the dealer do them. They actually remove them to get to the zerks.
Not doing 10 hour greasing of a couple JD zerks. They get the same 50 hour service as the other stuff, sans the Ujoints.
Going every other year on oil changes, synthetic of course, and 5w30 or 0w30.
Get realistic, JD, on those grease intervals and make those Ujoints accessible or sealed, apparently like ones on other cars, trucks and tractors. My neighbor says JD has gone sealed on the tie rod ends (that have been that way for 50 years on cars/trucks) on bigger JD tractors. I've only ever had to replace 1 (that's ONE) tie rod end on all the vehicles I've ever owned (those go karts I serviced one summer on Lake Texoma don't count: now they were rather awful).
I do not let my JD sit and idle for 20 minutes after starting in cold weather like the B2301 Operator's Manual says to do. It gets started and gets going soon as it's idle steadies out, which doesn't take too long. Use the low vis hydraulic fluid, of course.
Ralph
/ Probably stick with the JD 2 series. #2
Any tractor will have quirks and if it isn't a quirk to you it would probably be with other owners. I personally like Yanmar diesels because of how smooth they run and how long they seem to last. I think you will be happy with the one you have.
On the other hand: just found out JD has eliminated the dual brakes in the gen. 2. Would swing me back to the B2301 unless I can get a 3 series with them for not hp increase. Don't need the hp, JD.
Ralph
/ Probably stick with the JD 2 series. #5
If I had to choose between a Deere or a Kubota I would be unhappy, but go with the Kubota. My Deere dealer could not (would not?) repair the parking brake on my 855. Having confidence in your dealer is important unless you can fix stuff yourself. We don't buy expecting to need a dealer but the reality is that they are machines and they can break. Just another consideration besides price and spec's.
I think the 2032R and the 2038R have split brakes.
Don't need that much hp and fuel gobbling. Already, the 2025R uses far more fuel than the 4010 (about 0.7 gph vs. 0.46).
Ralph
Friend of mine has had a BX for years. He took his to the dealership closer to him now that it is carrying Kubotas. Said they were good. The local JD dealership is very close and is okay. They tend to overdo things. They screwed up on the lift pin locations for the LX4 bush hog on the 4010.
Ralph
/ Probably stick with the JD 2 series. #8
The number of cylinders has a big effect on how smooth a diesel will run, probably the most important factor. Inline 4 cyl diesels are not nearly smooth as an inline 3 cylinder based on balance and harmonics, and I can confirm that -- my Isuzu generator is a 4 cyl and much shakier than the 3 cyl in my my Kubota tractor.
My Isuzu is only about 17 hp (16.8 if I convert the 12.5 kw). Very smooth. Also very low in fuel usage: 0.35 gph last I checked and close to 200 hours. It would prorate to 0.42 gph for the 4010 vs. 0.46 it ran.
Whereas, the 2025R runs 0.63 gph. It would be 0.61 by prorate of the 4010. So, it isn't too bad, just too much hp.
Ralph
/ Probably stick with the JD 2 series. #10
Are you sure about the 2 drain plugs in the Kubota? My B2620 (which is basically the same as the B2601) manual shows two drain bolts and the split pan, but that is not what is on my tractor. Just a single sump and single drain.
My engine runs smooth as glass. A friend has a BX and it really shakes when first started, but my B is smooth.
I have read about leaks with the new single point flat faced couplers, but not with the individual Pioneer couplers. Mine hasn't leaked a drop.
And I wouldn't buy anything without individual steering brakes. Why did Deere change this? Cheaping out to increase profits I guess?
I like the Deere's too, but I have seen far too many horror stories with the 2R and the previous version, and those same problems seem to carry on year after year. The U-joints, bent loader stands, bent fuel tank mounting brackets, all those auto-connect features not working reliably, etc.
Seems like the 3R and up series are way better products.
Good to hear from Canada. I was going by the Operator's Manual that I downloaded. It shows 2 drain plugs. This is not a killer. Not bad opening drain plugs on the tractor.
The business about 2025R gen. 2 going to a single brake is a killer.
For those advising getting a used one that has 2 brakes, well, that's what I have already. I talking about maybe my next tractor. Kubota B wins out with lower hp available and dual brakes.
Ralph
/ Probably stick with the JD 2 series. #12
I like the Deere. It is the best looking compact tractor in my opinion. But they just seem to have little issues that follow them series to series.
And as far as Kubota, they seem to print a lot of misinformation in their owners manuals. I got to go to a dealer meeting once and one of the reps told me he thinks things get improperly translated to English.
But even the drain points and number of drain bolts for my hydro were incorrect.
Deere has a lot of great ideas....they just need to make them work correctly in the field.
/ Probably stick with the JD 2 series. #13
I just did the 50 hr service on my Kubota L2501 and yes it has two drain plugs, but studying it, it's because the oil pan is notched out so the drive shaft can be tucked up out of harms way. Which seems much better than having only one drain plug and leaving a quart of old oil in the sump. Or running the drive shaft below the oil pan. And both drain plugs are identical and side by side so no big deal.
But no, I would not try using an oil suction extractor on an engine with a notched sump. I must say the drain plugs are right there easily accessible with a socket under the middle of the tractor.
/ Probably stick with the JD 2 series. #14
3025e doesn't have spilt brakes either.
/ Probably stick with the JD 2 series. #15
same I did the 50 hour service on my 2650 saturday and it has 2 bolts. but was simple enough.
