Hi all,
Can any one help with information as to when this tractor was made.
Ford 5610 III 4 wheel drive
Serial number BC19420
Model LA414D
Unit 9H31B
Engine 206805 9H30
Transmission 9H29B
Hyd pump 9H24B
Hyd lift 9H30B
Front axle 709/19 F56 /0011340 Ref number 122965
This is a machine that is up for tender, has been used by the local council and meter showes 1798, I assume hours. It has been standing for the past 6 years and the reserve price is very low around 1500 USD.
I have spoken to the last person who drove it and information is, needs new :- battery, fuel primer, clutch, rear brakes need replacing, PTO switch.
I am sure there will be more.
I have been told that the front axle is the same as 6610.
This is the type of machine where the gear shift levers (2)are situated just under the steering wheel on the right hand side (not as conventional on gear box)
Is it worth chasing this machine?? are they bullet proof ??
I only have 2 days to put in tender price, what's it worth?????
Hoping someone can help
many thanks
Rabet
Model LA414D
Unit 9H31B
Engine 206805 9H30
Transmission 9H29B
Hyd pump 9H24B
Hyd lift 9H30B
many thanks
Rabet
