Chipper Scored a used BX62 Wallenstein
   / Scored a used BX62 Wallenstein #1
Boondox
Elite Member
Craftsbury Common, Vermont
Deere 4044R cab, Kubota KX-121-3S
Found it about an hour away, lightly used then stored for four years in an aircraft hangar. Knives sharp as new, hardly any scratches in the paint. $2000. A real beast!
Images show the chute open for easy access to the blades. Looking forward to years of use
D4E70832-2BE8-4A7B-9FD9-A6111A406B9A.jpegE112CBBF-F249-469B-A90B-84E3AF5D2A87.jpeg2F150145-2E2A-4EB0-B3CC-1F057ECF74AC.jpeg95C83552-F028-4053-A56B-1CD9282FB54F.jpeg
   / Scored a used BX62 Wallenstein #2
Wallenstein makes a great chipper. Mine runs as smooth as a Swiss watch with near zero vibration. Good find.
   / Scored a used BX62 Wallenstein #3
Great score!!
   / Scored a used BX62 Wallenstein #4
That's awesome! There is a local auctioneer that sells a chinese copy of it, and believe it or not it is a great unit. They generally sell for $1500CAD each. I was able to get 2 at a sale for $550 each, took them both which REALLY annoyed the down bidder lol.
   / Scored a used BX62 Wallenstein #5
That IS a great find. I've had my Wally BX62S for eight years now. Never a problem. Every spring it's what chips my young pine trees. Around 900 to 1200 every spring. I'm quite careful and after eight years I'm still on the same side of the cutting blades. Soft, young pines & no dirt or rocks.
   / Scored a used BX62 Wallenstein #6
I also have one. I bought new. Shear bolts are 10mm, but I use 3/8", easier to find/buy. I found mine does not like grape vines. It plugged up, so I no longer try to chip them.
I bolted 4x4s to the skids to make it sit higher for less drive shaft angle.
   / Scored a used BX62 Wallenstein #7
Had one, sold it last year. Roasting sticks is a lot less arduous than chipping them. Quicker too.
   / Scored a used BX62 Wallenstein #8
That does become the question on some occasions.
and..........just as Zebra noted about grape vines...........try some yucca plant some time.:(
   / Scored a used BX62 Wallenstein #9
Zebrafive - I learned, in a big hurry, there is an alternate to the Grade 8 OEM shear bolts. The dealer charged $8.50 each. I swapped over to 3/8" machine bolts.
   / Scored a used BX62 Wallenstein #10
What grade are the 3/8" bolts?
Not positive but think I've been using bulk 10MM metric bolts. Can't recall the grade but believe I researched it.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2024 Timpte 40ft Hopper (A55314)
2024 Timpte 40ft...
2013 Club Car Carryall 252 Electric Utility Cart (A51694)
2013 Club Car...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
