No NX4510 around?
/ No NX4510 around?
Threepoint I appreciate the advice. I know I was not planning to put a hydraulic tilt so I'm guessing in my ignorance of implements I can only think of a stump grinder that uses 2 sets. But I totally agree about the empty slot there would look complete with all the levers lol. Would it be a true remote or split off one of the others? Either way I can call on Monday and see how much more money to fork out.
/ No NX4510 around? #22
Hawk3145, yes, the 3rd remote kit would be a true remote, identical in appearance and operation to the second remote that you've already ordered. Even the color coding of the lever would be the same, blue, for lack of a third color for the levers at Kioti. :)
But the third remote is not at all necessary. I just know that it's come in very handy for me. We here at TBN are always ready to help another member spend his or her money. :laughing:
BTW, for clarity, when I refer to an offset cylinder for a rear blade, it has a different function than that of the hydraulic tilt cylinder in a "top and tilt" 3pt system. It is mounted on a rear blade (also called a back blade, scraper blade or snow blade) to swing it out farther ("offset" it) to the side of the tractor. Very useful, for example, to push snow farther off the road/driveway without actually driving onto the shoulder. Also very useful for ditching, when used in combination with either manual or hydraulic tilting of the blade. But not all rear blades have an offset capability to begin with. And even if a blade does, it may not be designed to accept an optional hydraulic cylinder upgrade.
There are numerous threads on TBN discussing the various other uses for multiple rear remotes. Here's one from 2016 than will give you some ideas: https://www.tractorbynet.com/forums/attachments/354429-rear-remote-hydraulic-attachments-implements.html
Here's another from 2006: https://www.tractorbynet.com/forums/buying-pricing-comparisons/91310-3-rear-remotes-worth-2.html
/ No NX4510 around? #23
SNIP
I recently bought an NX5010C and opted for 3 remotes. In one setup, I use 2 for my ditch bank flail mower and the other for a hydraulic top link to adjust cut. My future setup is a landscape rake with offset and angle cylinders. For that, the third remote will be used for tilt via a hydraulic side link.
Apparently outside the US, 3 remotes are normal options ordered from directly from Kioti with longer bolts available as well. :confused3: The outside of the US third remote lever is green while number 1 is blue and number 2 is gray. I made one of my remotes a detent, so that has the gray lever and the other two are blue. The second and third remotes were $350 each installed. The dealer ordered longer bolts from Fastenal to stack them.
/ No NX4510 around? #24
I did the exact same thing with my three remotes on the color coding.
/ No NX4510 around? #25
Is anyone putting the 3rd remote on an open station ROP NX 4510 or do you all have cabs. I am having a real problem with my dealer getting my 3rd remote on. They keep telling me Kioti is shipping the wrong remote.
/ No NX4510 around?
I thought for an open station it was not an option. Even in my cabbed model my dealer had issues putting mine on. I gave him the bolt size and they stated they still did not fix so he used threaded rod and bolted it down and so far it has worked but only 25 hours on it. Bit there are far more qualified people on this forum that I'm sure can give you if its possible or not.
New Holland TC21 (A62177)
New Holland TC21...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A63689)
2021 Gehl RT215...
Trimble 2050 Display Screen (A64119)
Trimble 2050...
