L2501 hydraulic change
/ L2501 hydraulic change #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I changed the filter and fluid on my tractor, put in the amount the dealer told me my tractor would take and yet I see nothing on the tiny sight glass, experience has told me this means either it is overfilled or there isnt enough. Experience has also shown me that trying to add to it alone ( like Ive done in the past ) without watching the sight glass can easily lead to an overfill of epic proportion.
There has to be a better way of checking where Im at?
L2501 DT with a FEL and backhoe
Thanks
/ L2501 hydraulic change #2
How much did the dealer tell you to add? What is the system capacity according to the book? I'd have to check but I think the capacity may be eight gallons. I may be mistaken but for some reason that number sticks in my head. Since you can't ever fully drain a system that means it would hit capacity at a bit less than that.
/ L2501 hydraulic change #3
While SUDT is good stuff, it's clear and difficult to see so I use Chevron Synthetic All Weather THC. It's Kubota approved and it's orange (of all things) so I can see it. You can buy dye specifically for hydraulic fluid at a JD dealer but it's not cheap.
/ L2501 hydraulic change #4
I changed the hydraulic and transmission filters this weekend, along with, oil, oil filter, air filter and fuel filter. I have not done a full hydraulic oil change yet, so when adding make-up oil I could see it against the paper white background. I poured in a little at a time. It is very time consuming. It does help to actually have it in a dark garage with a white LED flashlight on the site glass. Helped me anyway.
I think my Kubota warranty would expire if I put JD green dye in it :)
Called several dealers today, no way of telling, one suggested unscrewing the sight glass, I will prob do this. Thanks for the replies
/ L2501 hydraulic change #9
It's actually red dye. ;-p
Just make sure to tell anybody you have work on it or sell it to. They might wig out you filled it up with ATF outherwise.
/ L2501 hydraulic change #10
I overfilled mine, doing my 50hr. Once I drained out about a gallon, you could totally see the difference at the sight glass. One other place to check, look down into the fill plug with a flashlight, it should not be full. The orange dye would be my choice. ;)
/ L2501 hydraulic change #11
Kubota does not approve aftermarket oils. Your Kubota dealer may tell you it is OK to use, they may even sell it. Chevron may claim it is safe to use in Kubota equipment. But Kubota does not officially approve the use of anything except Kubota fluids.
/ L2501 hydraulic change #12
Maybe I should have said, 'Meets and exceeds Kubota requirements' instead. Which it does and I've been using it for a number of years in my M's. if I owned a hydrostat which I don't, I'd only use SUDT. SUDT is what I use in my GS 850 Kubota side by side btw.
/ L2501 hydraulic change #15
I think I said it's not widely available but I get it from my jobber, they are a Chevron Distributor, Schrader Oil in Toledo, Ohio. Believe they have a website as well but not sure if they see it on there.
/ L2501 hydraulic change #16
thanks,
A few searches come up with Zero local suppliers. fuggetabout a price....
