Loader h165 FEL Question
/ h165 FEL Question #1
El Kabong
John Deere 4105
Hello, just joined this forum and have a question. I have a 2014 John Deere 4105 I bought new. It has the H165 FEL. The problem I am having is, the part of the arms that the bucket hooks to are not even. This has just happened and I can't find anything bent, but, when I take just the bucket off, the arms are not aligned and they used to be. I can't find an adjustment for this. Any chance someone can help me with this, or point me in the right direction? Thanks
/ h165 FEL Question #2
:welcome: to TBN
Please post some photo's that show the problem.. may help with an answer.
/ h165 FEL Question
:welcome: to TBN
That's a good idea. I will pull the bucket tomorrow, that way my question will make sense. Thanks
/ h165 FEL Question #4
My guess is the timing rod between the bucket mounts, high lighted in yellow, lost or sheared pin 17
/ h165 FEL Question
Thanks for the diagram, it is part number 9 that is mis-aligned. I looked at the pins, ( 17 ) and they were still there, but, I didn't remove them. Thanks again for another thing to look for. I will check that and report back in case anyone else has this issue.
/ h165 FEL Question #6
If a pin, 17 did not shear (one of them), the timing rod, 16 may have twisted. I guessing a pin sheared.
/ h165 FEL Question #7
Agree with Zeb that #17 is sheared off.. happens and sometimes is hard to notice. I put the bolt back in from the bottom up, then it drops away when sheared and doesn't appear to "look" like it is ok. I use a lock nut on top and keep a supply of the shear bolts.
/ h165 FEL Question
Thank you gentlemen, that was it, pin 17 was sheared, but, still in the rod. Thanks again for all the help
/ h165 FEL Question #9
:thumbsup: :thumbsup: thks for letting us know.. bt
New/Unused Wolverine 45in Bucket Clip on Pallet Forks (A61166)
New/Unused...
2025 Kivel Quick Hitch Skid Steer Attachment (A61567)
2025 Kivel Quick...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
RING 2 STARTS HERE @ 9:15 AM (A62130)
RING 2 STARTS HERE...
2010 Dodge Grand Caravan Van (A61569)
2010 Dodge Grand...
