yanmar 1610d wants to run away
   / yanmar 1610d wants to run away #1
kenhar
romance, ar
6640 ford, 1135 massey, 1610d yanmar, 1957 350 international utility
Started my yanmar 1610d today and it wants to run wide open. It has set idle for a couple months, ran perfect when last used. The throttle is not stuck, linkage of both hand and foot control works freely. Do I have an injector problem? I've owned the tractor over 5 years and never had a problem with anything other than trying to figure out some of the Japanese symbols.
   / yanmar 1610d wants to run away #2
The throttle may not be stuck but check under the hood to make sure it is actually controlling the linkage there. It sounds like something is slipping on a shaft somewhere.
   / yanmar 1610d wants to run away #3
I would pull the injectors and have them pop tested
   / yanmar 1610d wants to run away #4
Not sure about the 1610, but on a lot of older Yanmars the throttle lever actually connects to the governor. It could be as simple as that rod coming loose.
   / yanmar 1610d wants to run away #5
Mini, why would you have the injectors tested????
OP, check the linkage first without starting the tractor. Look if the linkage moves a lever on the injection pump as you move the throttle handle.
   / yanmar 1610d wants to run away #6
I don't know the specifics of every engine. I just know that run away engines are caused by excessive fuel or fuel vapor entering the engine either thru the air intake or the injectors
   / yanmar 1610d wants to run away #7
I've never seen a leaking injector cause a runaway condition. Symptoms usually include poor performance with black smoke or cylinder wash down resulting in fuel in the crankcase.
   / yanmar 1610d wants to run away #8
It might sound daft, but have you checked the oil level. I had one run away after diesel had leaked into the engine from a faulty diaphragm on the lift pump, Because the ``oil`` level was high, vapour was being pumped into the breather. and away she went.
   / yanmar 1610d wants to run away #9
kenhar, come join us over in the Yanmar forum. If your problem isn't the linkage (most likely) then it almost has to be in the governor. Someone there can advise you how to free it up.
   / yanmar 1610d wants to run away #10
How have you been shutting it off while ?running away? If it's blow-by,a physical condition, it is very hard to stop. If it is the governor or some other fuel supply problem, shutting off the fuel supply will get it done. If you can shut it off normally, then it is probably a stuck accelerator/governor linkage.
If it's not the accelerator/governor it could be excessive blow-by from the crank case. Check the oil level. If it's low it is going some where and that some where is probably the top of the piston.
2014 Chevrolet Cruze (A50324)
2014 Chevrolet...
John Deere 443 4 Row Corn Head (A50774)
John Deere 443 4...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
UNUSED AGT ATK-B1000 2 POST HYD CAR LIFT (A51244)
UNUSED AGT...
