Ford 7.3L Gas Engine
   / Ford 7.3L Gas Engine #221
Tractor guy, you’d better do some research in the new 5.0L. It’s far from reliable, and only getting worse. It’ll never make the 2021 redesign.
   / Ford 7.3L Gas Engine #222
Hadn't heard anything bad about the 5.0 but I haven't researched that engine for problems. I had a Mustang GT with that engine that had no problems. I've seen quite a few of the F150s advertised with 200k on them.
   / Ford 7.3L Gas Engine #223
Sure are a lot of people that get spooked by an Internet posting of a few problems with an engine. All engines will have a lemon here or there.
   / Ford 7.3L Gas Engine #224
I have posted before where the 2018 and newer 5.0 are having oil consumption problems. There is quite a bit of it on the F150 forums. Like most cases most people are fine but reading between the lines, I think it is an issue. They are aluminum blocks and in the past they had cylinder liners but in 2018 changed to something like a plasma welded liner(not the exact term).
   / Ford 7.3L Gas Engine #225
Here is a article about the plasma wire sprayed liners in the 5.0 engines.
Ford Finishes F-15 Powertrain Makeover | WardsAuto
I'm glad the 7.3 has push rods as that makes for a very short timing chain. The overhead cam engines need super long timing chains that may have issues with tensioners.
   / Ford 7.3L Gas Engine #226
Motorcycles, Porsche, Mercedes, and others have been using hypereutectic aluminum and plated aluminum since the 1970's.
Chevy Vega tried to use hypereutectic aluminum too, but didn't properly heat treat the cylinders. And then bolted a huge cast iron cylinder head on top to ensure the block warped. Could see the distortion in wear on cylinder walls as the block twisted between hot and cold.
Silicon in aluminum can be made to crystalize above the eutectic point. By placing heaters in the cylinder bores while the cast block cools one can force this crystallization to create a very hard silicon surface. GM thought they could get away without the heaters.
Plating cylinders is a means of avoiding the expense of having to slowly cool the casting.
There are several companies in the USA who re-plate aluminum cylinders. 2-stroke dirtbikers know them well.
   / Ford 7.3L Gas Engine #227
Earlier in this thread I expressed my feeling that a pushrod engine was going backwards in design. I didn't know much of anything about the 6.2 offering. The 5.0 Coyote engine has been pretty reliable in both the mustang and truck configuration.
A while back I saw a F250 with a 6.2 for cheap and the dealer said it had a knocking noise in the engine. Doing some research online I found numerous complaints of 6.2 gassers with engine failures and noises so I decided not to go down a repair path. Seems like the same issues Ford had with the 6.0 diesel engine. It's hard to understand how Ford has remained the top selling truck with their recent history of engine problems.
I知 not sure where you get the 6.2L in the Super Duty being a bad engine. Yes, some have had issues, but no moreso than any other engine. In fact, my research showed just the opposite. The 6.2L has a very good record. The 2011-2016痴 are **** near indestructible, if used as intended. I have seen a few issues with the ?7+, but no more than any other engine.
The only engine in this range that has a better record is the GM 6.0 L, which ran for twenty years and they got all the kinks worked out. The issue with the 6.0L is much less capability than the competing engines from Ford or Ram. Irrelevant as the 6.0L is no more, GM has a brand new 6.6L gas.
What痴 really interesting is there have been a lot of engines that were more reliable in their earlier versions. See the Ram and Dodge 5.7L, Ford 5.0L (post 2011MY), Ford 6.2L (as discussed).
When checking the 6.2L durability, make sure you are comparing the Super Duty version, not the one in the Raptor/F-150. The Super Duty is slightly 途etuned for longevity over brash performance. The F-150 version did have more issues, mostly because people modified an already high outputting engine.
   / Ford 7.3L Gas Engine #228
Plasma coated.
I lived it. Factory 2018 5.0L engine burned 1-1/2 quarts in 3,000 miles. Had many consumption tests up to 23,000 miles IIRC before first TSB was finally issued. THEN, did the PCV change and consumption test per TSB. Failed. I had done one privately before, and knew it would fail under Fords observation, too. So, engine burned over the 1 quart in 3,000 miles again, and new long block was installed.
Second engine, same thing. At 48,000, I wasn’t willing to go another long block. I had only had the truck a year since new. Off it went and I got the 3.0L Stroke.
A few weeks after trading, Ford said oil consumption on the 5.0L is due to PCM programming. That has since been shown to be a joke. So then, new dipsticks are being offered with TWO quarts between full and add oil. No thanks. In close to 3 million miles driving, I’ve never had an engine burn oil anywhere close to my 2018. You watch. The 5.0L won’t see 2021. Shame too. I loved the truck, and loved my Corsa Extreme on the truck, but as long as they keep moving the goal line on the standards to keep the 5.0L in service, I’ll pass. I didn’t know when I bought it the 5.0L was a redesign. I can’t imagine the 7.3L is not a cast iron sleeves mill. THAT would be a mistake in my book.
   / Ford 7.3L Gas Engine #229
Ford has a bit to do to catch up on excessive oil consumption if they want to compete with some previous worst offenders...
Bought a new 1977 VW Rabbit back in the day...
Volkswagen had the nerve to actually Print in the owners manual that 500 miles to a quart of oil was to be considered normal use for the purchasers new car.
in 1979 they printed 2.4 quarts per 1000 miles is OK:eek:
Then government forced VW to pay to have new upgraded valve guides and seals installed on All the offending models /years.
   / Ford 7.3L Gas Engine #230
Researching maximum allowable oil consumption tolerances for any engine will be maddening. Kawasaki twins are allowed 1 pint in 50 hours. 25% of crankcase capacity.
AGRICO FERTILIZER SIGN (A58374)
AGRICO FERTILIZER...
2006 Ford Taurus SE Sedan (A54815)
2006 Ford Taurus...
2011 JACK COUNTY 130 BBL VACUUM  TRAILER (A58214)
2011 JACK COUNTY...
2019 Chevrolet Tahoe SUV (A56859)
2019 Chevrolet...
light tower (A56857)
2016 GREAT DANE 53’ REEFER TRAILER (A58018)
2016 GREAT DANE...
