Rear Inverted Snowblowers 2019
   / Rear Inverted Snowblowers 2019 #201
Hillbilly, too bad you live so far from me. I'd give you a sweet deal on my 78" inverted meteor thats only been used 3 times. I am still not happy with the results of the blower. I will try like heck to figure out how to adjust the top link to get it to scrape better. Unfortunately havent had snow in a while, and none on the 10 day forecast. Also, I foolishly thought since it was inverted I would hardly be turning my neck around. This is not true. I am looking backward probably as much as if it were a rear facing blower.
I bought a 78" inverted Meteor last fall and after reading your posts was a little concerned I'd made a poor choice. But since the arrival of snow here in Vermont I've had nothing but excellent results with it on my 600 yard gravel driveway with hills and dips along its length. I have the driveway marked with reflective fiberglass poles and simply ensure that the rear tire clears them by a few inches...knowing that the blower will get right up to them without me turning my head. This time of year it's not any faster than plowing with my rear blade angled, but later - as the snow builds up - I won't have to waste hours pushing snowbanks back to make room for more snow.
The one problem I had with it was user error. I was using the optional rear blade to pull wet, heavy snow out from between a vehicle and a structure with the PTO off. After a few pulls that snow was pushed up into the chute packed to the point where I had to clear it by hand. Lesson learned: keep things turning when using the rear blade.
I'm absolutely delighted with my Meteor and have been praying to the snow gods for more storms.
Pete
   / Rear Inverted Snowblowers 2019 #202
Smyth Welding dealer in Red Deere Alberta 780 km away.
Dave M7040
I checked out the dealer website and there is no information on blowers. I also checked out the Smyth welding website and there is not much information on there either. When I click on the "more details" button on each of the blower types it just goes to a bigger picture of that type of blower. I can't find specs for any of their blowers on the website. As I recall your blower has a big fan and I would like something bigger than the Meteor and Farm King blowers I'm looking at but not at a huge price increase. I guess I'm asking for too much.:)
Pete
Glad you like your Meteor blower. My biggest concern is travel speed and that will be dictated by either the tractor running out of hp or the blower fan being undersized. I want to find the right blower to make my tractor work efficiently and I've seen some videos that show tractors smaller than mine ripping through 6" of snow and others where the tractor is bigger than mine and creeping along. I would prefer not to get the blower that requires me to creep along.
I'm going to make a few more calls this morning before making a decision whether to go ahead with the Farm King or wait until next year and spend more time trying to find a decent deal on a better blower.
   / Rear Inverted Snowblowers 2019 #203
This is from the website at Smythe Welding (I've seen good reviews on TBN):
Do you have a long lane, and don稚 like to back up but have to get snow out of your way? Consider hooking your mid-size tractor on to one of our pull-type blowers and leave the snow behind you!
They comes standard with a flat bar cutting edge on the bottom to help cut through the tire marks. The wear shoes on the back, keep you out of the gravel when the ground is soft. These two stage blowers are easy on horse power, and very easy to operate. No more backing up to blow snow!
Technical Specifications:
CUTTING WIDTH AUGER FAN WEIGHT (LBS)
54 14 6 x 20 549
60" 16" 8" x 24" 610
66″ 16″ 8″ X 24″ 680
72" 16" 8" x 24" 715
78″ 16″ 8″ X 24″ 750
84" 20" 10" x 30" 1115
90″ 20″ 10″ X 30″ 1195
96" 20" 10" x 30" 1345
102" 20" 12" x 30" 1595
Smyth Welding & Machine Shop Ltd.
37452 Glen's Hill Road, Auburn, Ontario
Voice: 519-529-7212
   / Rear Inverted Snowblowers 2019 #204
Hilbilly,
I only have a 40 HP tractor with 32 PTO HP. I got a 74" FarmKing pull blower ($4000 on sale during the summer) but have only had to use it three times so far. Deepest snow being 6" and it works well.
Had about 4" to take off yesterday. To check how it handles more snow, I used my front mounted back blade to windrow the snow into the center of the drive from both directions and then ran over the windrow with the blower. It ate it up no problem It sure is nice driving forward.
BTW, build quality seems good. I like that the shear pins are common grade 5 bolts attached with nyloks. I sheared one on the first use as I have a gravel drive and tired going too fast...that gave me a build up of gravel that stalled it out. I adjusted the top link and so far no other issues. Shear pin is easy to get to and change.
Not sure how the FarmKing stacks up against the "better" blowers. I get 120-150" of snow a year and only do my property. I am satisfied but maybe I do not know what I am missing with the more expensive units. It moves snow efficiently and I have no more mounds of snow from plowing. Seems all I need.
The SSQA plate on the front lets me mount my 3ph attachments so I use both my back blade and rake. Good enough for light work and it is nice being able to use the blade for back blading snow. If I need the bucket or forks it is easy to change over. For just over $200 delivered it is not expensive for the flexibility it affords.
Amazon.com: 3 Point Attachment Adapter Skid Steer Trailer Hitch Front Loader case: Home Improvement
   / Rear Inverted Snowblowers 2019 #206
Airbiscuit,
Thanks for that info. I couldn't find it on their website, so I called them and got the same info regarding the fan sizes. That's a huge jump from the 78" to 84" blower. I also got prices. The 78" is in the same ballpark as the 2 blowers I've been looking at, until shipping is added. That's the killer! I have to add about $1,500 to everything coming from back east.
shooterdon,
Thanks for the feedback. The more I look into this the more I'm inclined to get the Farm King instead of something with a bigger fan. Just too much more money. There are some things I like better on the Meteor and if I could find one locally for the same price as the Farm King I would get the Meteor.
   / Rear Inverted Snowblowers 2019 #207
Re: Farm King. I have a very old Farm King finishing mower, their 6' landscape rake and 6' rear blade. All seem to me to be very well built. I got the finishing mower used with a Kubota L275 DT 15 years ago and use it a lot. I had to replace spindles, blades and wheels because it had seen rough service cutting between grape vine rows. I use it a lot and have not had problems since. However, the sealed spindles are getting very noisy so I will have to eventually do something about that.
The rake is quite heavy duty as is the blade. To my untrained eye the welding looks good on all their equipment.
   / Rear Inverted Snowblowers 2019 #208
   / Rear Inverted Snowblowers 2019 #209
Airbiscuit,
shooterdon,
As stated before, for most snows of around 8" the speed with my 28 PTO hp tractor is a very fast walking pace or more. I really don't want to go quicker than that, even if I can. What slows me down are uphill sections. I think that is due to the HST requiring more of the power. But going downhill I can motor right along. The odd times(like lately) when blowing 12" of cement I do have to use low range and still manage a normal walking pace even uphill.
It snowed all night again and is forecast to snow all day. This evening it is to warm up and rain. So I guess the best plan is to head out after noon and get the snow out of the way. After the rain cooler weather and more snow is forecast so that will be fine. It is the wet snow that is not as much fun.
Here are a couple of photos of this morning from my upstairs window:
The one thing that does work good is the blower really blows extremely well. I see others inquiring about moving lots of volume and trying to figure out how the 5 blade fan affects things. I went through 6 inches of snow at 4 MPH no problem for a half mile continuously. I felt I could have gone even faster if I wanted to get crazy but saw no need. It eats snow like mad and throws very far.
Can someone with an L6060 help clear up RPM's for me. There is no PTO marking on the dial in tractor, so I looked in the manual and it says rear PTO RPM is 2500. So that is what I blow at. It seems unnecessary to have to have the RPMS so high, even though I generally am a very high RPM user all round. Is 2500 really the rear PTO RPM? Thats not far from redline? I was too scared and uneducated as to what might happen if lowered the RPMS to 2000? WOuld it hurt the tractor or just not throw the snow so far. I don't need to throw the snow 40 feet.
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2008 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A58375)
2008 CHEVROLET...
2007 JLG Skytrack 8042 8K Capacity Telehandler (A59213)
2007 JLG Skytrack...
2016 Hyundai Veloster Hatchback (A56859)
2016 Hyundai...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58216)
2004 VE...
EZ-GO Freedom RXV Electric Golf Cart (A57149)
EZ-GO Freedom RXV...
