Ford 6.0 diesel; the good, the bad, the ugly?
/ Ford 6.0 diesel; the good, the bad, the ugly? #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
I'm still kicking tires on ton trucks... mostly looking on Craigslist for something below the rust belt. My criteria is pretty liberal; manual shift, heavy 3/4, but preferably a ton truck. Right now I'm looking at mid-2000, as they are in my preferred price range for a truck which will probably see 5000 miles per for the next few years, then a lot less after that.
Currently I find this F350 rather interesting [FONT=Verdana,Geneva,sans-serif]https://atlanta.craigslist.org/eat/cto/d/monroe-2006-ford-f350-super-duty/7032105466.html.
I may consider taking a ride down next year (month), assuming they still have it. The 6.0 makes me nervous though, it seems like the Ford Diesels of that era had some growing pains as they were introduced to emissions.
[/FONT]
/ Ford 6.0 diesel; the good, the bad, the ugly? #2
There are some great Youtube videos out there that spell out EXACTLY which engines to get and which to avoid. Some were truly disposable after a certain mileage.
/ Ford 6.0 diesel; the good, the bad, the ugly? #4
Run from the 6.0L.
The cost to correct it's designed in issues will easily move you into the later generation of Powerstroke. Way to many issues.
/ Ford 6.0 diesel; the good, the bad, the ugly? #6
Some people claim they can be fixed, but from what I’ve seen they’re pretty much disasters. The 6.4s were perhaps even worse. I’ll never own one. Get a 7.3 or a gas burner. For low mileage a gas burner is probably the better option. 7.3s are expensive.
In other words keep looking, which is what I'm leaning toward. There's probably a reason why the price is only 6900 after all. I also agree about the gas (not 5.4) engines, they tend to be les money and are easier to swap if the need arises.
/ Ford 6.0 diesel; the good, the bad, the ugly? #8
My only experience with a 6.0 was when they gave me and my partner a new ambulance with a 6.0 and 17 miles on it. It was gutless compared to the 7.3 it replaced with 100,000 miles. We asked for the old unit back but no dice. I was not there long enough for the mechanical issues that seem to plague it to show up.
/ Ford 6.0 diesel; the good, the bad, the ugly? #9
If the 6.0 has not been bullet proofed it's a time bomb.
/ Ford 6.0 diesel; the good, the bad, the ugly? #10
Sorry hit wrong key. You would be much better served with a 7.3 . Bulletprofing a 6.0 will run you 5 -7 g 's and its still no garrentee . Bullet proofing consist of EGR delete and oil cooler relocation . Problem with 6.0's is the EGR gets clogged which overheats oil cooler which overheats engine . The 6,0 has only 6 head bolts per cylinder and that with over heating leads to warped heads leaky head gaskets . Lots of people buy 6.0 cause you can get them cheap and they do produce more hp than a 7.3 But it's gona cost u . You can get a nicer newer truck with a 6.0 [ king ranch or Harley davadison edidition ] but with a time bomb for a engine what good is it.:drink:
/ Ford 6.0 diesel; the good, the bad, the ugly? #11
I would have the 6.0 before the 6.4 any day of the week. Had the choice of ordering the 7.3 or the “ new and improved” 6.0 with more power. Last time I’ll fall for that ! Each year of the 6.0 had it’s quirks, after delete and tune it’s been fine.
/ Ford 6.0 diesel; the good, the bad, the ugly? #12
I owned a 2004 Cummins for several years. Had a 150,000 mikes when I traded it in. Solid drive train while I owned. The truck was just ok. Rust was an issue and wind noise was bad. My general take on trucks from that era, they just aren’t that great compared to newer truck, but for your use, just a little bit of use each year,probably serve your purpose. The problem with diesels is if there is a major problem, it’s expensive, injectors or a injector pump being very expensive.
I always remember a guy on the Cummins Forum posting his expenses for his truck. His was a 2004 2 wheel drive dually as I recall. He put a lot of money into the truck, but he was a hot shoter a put a lot of miles on it, so the cost per mile was really good. He had some 900,000 miles on it when an injector over fueled and he needed a new engine.
/ Ford 6.0 diesel; the good, the bad, the ugly? #13
If they're only asking $6900 for it, I'd let it sit, something doesn't smell right. The Ford 6.0 can be a very good engine, but they take a lot of flak because you only hear about the bad ones.
They are maintenance intensive, which a lot of people don't keep up with. Fluid changes must be done on schedule or the results will get into your checking account real quick. Some of these engines have gone over 500K miles, some blow at 80K. Oil has to be changed at 7500 miles or less, fuel filters have to be changed every other oil change. If it throws a check engine light, it shouldn't be ignored to see if it will go away. They really don't like short trip driving, it's hard on the turbo, the batteries and they don't like to idled for long periods.
I inherited mine from a relative, it's almost completely stock other than the EGR delete and a coolant filter. I've done a few preemptive modifications to it to hopefully prevent a major blow up, maybe to the tune of $300 or $400 worth of outlay. They also need to monitored so you can shut it down if you see something not right.
Mine currently has a little over 118K on it and the only thing I've really had to do to it other than fluids and filters is one glow plug, which cost a whopping $10.
In other words it's not an engine for a casual user, short trips will kill it slowly, it needs to be taken care of - so for a large percentage of the drivers out there, it's not the one they need or want.
The 7.3 is a pretty good engine and doesn't require near the amount of preemptive care the 6.0 does.
Ford also put some V10 gasoline engines in those trucks, seems most of them had manual transmissions, but they're hard to find and you wouldn't believe how fast they can drain a gas tank.
I'd suggest a F350 with the 6.2 gas engine in it.
/ Ford 6.0 diesel; the good, the bad, the ugly? #14
The 6.7l is where you want to start with Ford. The 7.3L is great, I just sold mine... But it's far under powered today, even with a +100 hp tune in it.
The 6.0L PSD is not just some dailies as someone above claims. The extreme strong majority of them had it will be expensively problematic. To fully head it off, $400 might order the ARP head studs... But that's just warming up. You need much more.... And much more cash to get in front of that mess.
That is likely the single most horrible engine design ever released. I can't think of an engine that had a higher failure rate.
/ Ford 6.0 diesel; the good, the bad, the ugly? #15
/ Ford 6.0 diesel; the good, the bad, the ugly? #16
Yep. My buddy Glenn is a Ford diesel tech. I used to go up to the dealership on Sundays during the 6.0L era/hayday while the dealership was closed and we would pull 3 6.0L Superduty trucks in on Sunday morning and in 8 hours have all 3 trucks with cabs in the air and be started on stripping the accessories to pull heads.
The dealership stocked ARP head stud kits and Innovative Diesel Performance modified EGR manifolds and blocker plates. As fast as he could pull cabs, more trucks were brought in.
Eric and his dad Ted at Innovative Diesel were one of the very first to pioneer the hardware fixes for that turd.
I've worked on more 6-leakers than I could count. Despise that thing, an embarrassment to Ford and International.
/ Ford 6.0 diesel; the good, the bad, the ugly? #17
Who ultimately was to blame for the crappy 6.0 design, Ford for directing International or International for trying to shave costs or rush an engine out? I thought the bottom end came from bus engines and was a solid platform?
/ Ford 6.0 diesel; the good, the bad, the ugly? #18
I have a 7.3 and a 6.0. I love my old 7.3 but the ride and cab noise is crap compared to the 2005+ 6.0's. My 7.3 has been solid only replaced the water pump and batteries, but now the torque converter is going out. My 6.0 have been a great truck im the 2nd owner. The previous owner had it bulletproofed (headstuds, egr delete, oil cooler, fuel rail crossover) but it had a High pressure oil leak from the dummy plugs when I got it. I think it was like $160 and a few hours of my time to fix. I would not be afraid to own a 6.0 if the price is right, the ride is great and the transmission is far smoother than the old 4r100. I find most 6.0 haters have never owned one but have heard from a friend who knowns a guy who married another guy that they hate their 6.0. When my dad bought his 6.0 new it had blown a head gasket while under warranty and had the turbo bearings go out but has been good since except for the FICM which went out due to a bad alternator.
/ Ford 6.0 diesel; the good, the bad, the ugly? #19
Anything in that era is getting to be old. My 2003 F450 is a great truck. Love the 7.3 and stick shift. But I've done a lot to it. And it needs more and more. Currently need a dump body and radiator. Its modern enough that repairs are not really easy and not cheap. But its far cheaper that buying new and I just love the old diesel truck smell. Nothing will be cheap, reliable and relatively modern.
If your handy, how about an older 1 ton like a C3500 or F350 from the 80's and 90's? If you can find a southern truck with no rust, the mechanical part is a piece of cake. The only downfall is power. Gas or diesel, neither will keep up with modern traffic.
/ Ford 6.0 diesel; the good, the bad, the ugly? #20
I realize I didn't answer your question either. From what I know, the 6.0 is a strong engine when running well. Once "bulletproofed" (which has a loose definition) it can be reliable, but out of the gate it needs work. From people I know that own these, the ones that have run and maintained their trucks like Gunny have had good service. Daily drivers and poor maintenance have been big issues as well as fuel quality. If you find the right combination of good fuel, fuel lubricant, clean filters, regularly drained fuel bowls, etc you might not have an injector issue.
The 6.4 is just epic. I wonder if it was Navistar's answer to: Can you build a more problematic engine than the 6.0? Yes. Yes we can.
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2012 HAMM 3410P PAD FOOT ROLLER (A62129)
2012 HAMM 3410P...
2013 BIG TEX 20 T/A GOOSENECK TRAILER (A60736)
2013 BIG TEX 20...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Toro Timecutter Max (A61166)
Toro Timecutter...
