Root Grapple for Rhododendron removal
   / Root Grapple for Rhododendron removal #1
Logan979
Member
Kubota
our property has an excessive amount of Rhododendron on it. Has anyone ever removed it with a Root Grapple ?
   / Root Grapple for Rhododendron removal #2
Your location would help. Would know something of plant size and your soil composition.
I was born and raised in Seattle where old Rhododendrons are huge and would defeat grapples on all but very heavy tractors.
Where I live in Florida, Rhododendrons are of modest size and most compact tractor grapples could pull them out.
Consider a Bucket Spade if you have a tractor of around 4,000 pounds bare weight. I have used a bucket spade for seven years to remove and transplant 25 - year old Florida Rabbiteye Blueberry bushes as large as Rhododendrons in Seattle, with similar size root balls.
https://www.tractorbynet.com/forums/attachments/328798-bucket-spade-today-fel-bucket.html?highlight=
   / Root Grapple for Rhododendron removal #3
I have moved and transplanted large Rhodies 6-8' tall x 6-8' around - they are shallow rooted. I go in with my bucket and get 6- 8" or so deep and under the root ball, then wrap a strap or a chain with burlap to protect the trunk, then tilt the bucket back and take it to its new location.
IF you just want to get rid of them a root grapple will work well. If you don't want to remove topsoil, then just cut them off at ground level and grapple them away.
Blue Ridge Mnts
Just trying to get rid of them.
   / Root Grapple for Rhododendron removal #8
As stated by Carl pthey have shallow roots. Are they large native ones, if so someone might be interested in them if you prep the roots as Carl says.
   / Root Grapple for Rhododendron removal #9
A Wicked Grapple rake should make quick and easy work! Most choose a 239 pound Wicked 55 unless they're really gonna put a crazy beat down on it. If so, 400 pound Wicked 60. Currently, both are in stock and the free shipping zone is huge.
The dozer like geometry increases a tractor's pushing/prying ability with a design which enhances the rollback force for popping up rubbish such as your rhododendron.
Here are a few examples..
Travis
I think these grapples have China made cylinders and nothing in the back of the grapple to prevent damage to hoses or other vital parts of Front End Loader from branches, sticks etc.. is this correct ?
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2223EB000633, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Pemberton 5460 Loader Root Rake (A56857)
Pemberton 5460...
2006 APPA TL (A55787)
2014 PETERBILT 388 (A58214)
2014 PETERBILT 388...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
