s470 Will not idle
/ s470 Will not idle #1
Flhermit2
satoh
Ok I got it ruining but now the throttle lever does nothing. It runs at one speed (I'm guessing about 1,000 rpm) Any help would be greatly appreciated
/ s470 Will not idle #2
The control rack on the injection pump is stuck.. possibly from old fuel..
Is there a removable plate below the inj. pump ?? remove it & see if u can get your fingers on the control rack..
Does the engine shut off w/ a pull cable or the key switch ??
If its w/ the key, theres an electric shut off solenoid that might screw into the block.. u can unscrew it and get your finger in the hole..
The inj. pump will probably have to be removed to fix the problem..
Exactly, I had to pull the injector pump and half a can of PB blaster and a plastic hammer but now it works.
Thanks for the reply.
/ s470 Will not idle #4
Not exactly the "ideal" fix.. but if its working.. run it..
I'm always available to do it correctly if the need arises.. just shoot me an email.
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
SPIN SPREADER (A64280)
2005 Freightliner M2 106 20ft. Reefer Box Truck (A61573)
2005 Freightliner...
2012 Blue Bird BB Conventional School Bus (A61573)
2012 Blue Bird BB...
2016 Caterpillar 304E2 (A64126)
2016 Caterpillar...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
