YT235 3 POINT HITCH OBSTRUCTION
/ YT235 3 POINT HITCH OBSTRUCTION #1
cabover4us
Back in Salem, New York
1987 john deere 855 sold and bought a YT235 Yanmar, love this tractor
Hello everyone, have another question, I ran into a problem last summer using my 72" 3ph mower.
I bought this tractor with the Woods BH75 backhoe, including frame mount.
Now, onto the problem, when I hook up to an implement. The bottom 3ph arms are pinned on and I can't have the sway links (turnbuckles) attached. They are unthreaded and hanging because rising and lowering the 3ph is hitting the frame mount for the backhoe.
As soon as I get home on friday I will post pictures and video. I cant be the only one with this problem.
I'm sorry for the delay, finally home and on vacation. I will get pictures up today, hopefully I can figure out how to attach video also.
Must have to be a magician to attach a video or picture.
/ YT235 3 POINT HITCH OBSTRUCTION #5
When I have problems loading pictures/attachments on any website, I usually go to the non-mobile site/selection, as that tends to be more user friendly for that type of stuff
/ YT235 3 POINT HITCH OBSTRUCTION #6
Can you flip the hitch pins on the mower? So you're lifting from inside the mower's hitch frame and not outside? This should narrow the lift arm positions a bit and maybe clear the backhoe subframe.
/ YT235 3 POINT HITCH OBSTRUCTION #7
In order to hookup the backhoe, you have to pull the 3 point arms. If you do not have spacers, it is a pain.
Currently at the dealers right now getting warrenty work done, doing the recall as we speak.
Able to get it back on monday, except I will be working and cant see the new parts installed, will have to wait till the following weekend I guess. I am certainly glad there was a recall on this problem.
Also, as soon as I'm able I will change my profile pic to show my Yanmar.
/ YT235 3 POINT HITCH OBSTRUCTION #10
I upload my photos to a site that stores photos. I use shutterfly, it's free, but there are others out there. It works well to upload from my camera or phone. Thing I like is when you load a photo from there to here, it shows up IN the body of the post full size, not the little thumbnail so many post here you have to leave the post, click on one photo, go back to the post, click on the next photo, and so on. Too clunky for me, so mine always go in the body of the post where you don't lose continuity of communication.
To load a photo that way, put in on a photo hosting site, then open your photo there and right click mouse over it, select photo location, and this pastes the URL of the photo into the clipboard of Windows.
Next, select the "insert image" icon (top row of icons, 3rd inward from the right end when in 'reply' mode) click to open. Box will pop up giving you two choices "From Computer" (the default) or "From URL". I use the From URL. Click to select it and a box opens to allow to right click, paste the URL you have in your clipboard from your photo site in that box. THEN....and this is critical......UN-CHECK the STUPID box right below the URL that says "Retrieve remote file and reference locally"....which would SEEMS like exactly what you want to do, but is actually a cruel programmer trick to aggravate the crap out of you, because if you don't UN_CHECK, you can't post your photo....go figure.
Then the photo shows up in the body of the post like this pile of logs at my mill.
enhance
Thank you so much, I havent been on here in a while. I will try the same photo service as you use, thanks again for those detailed instructions.
P.S. Tractor returned with new links (turnbuckles)
fits and works fine, nice jpb from Emricks Sales and Service South Glens Falls, NY location.
/ YT235 3 POINT HITCH OBSTRUCTION #12
Did they turn down the retainer shaft or bore the powder coat off the inside diameter?
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2015 Audi A4 AWD Sedan (A64557)
2015 Audi A4 AWD...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
