New Member
/ New Member #1
Bob50
1990 Kubota 2150
Hi All,
I want to thank you for allowing me to become a member. I own a John deer skid steer, but a couple of months ago, I bought a Kubota B2150 It has; FEL attachment. It's Hydro, Power steering, 4x4, and as far as the tractor, ran great with 1000 hours. The tractor was sitting, so I had to reseal all the cylinders, and a bunch of hoses. This is my first tractor. I did a couple of jobs with it, and I am very impressed. The only tourble is when oil heats up, and Im working it, that when ever cylinder or hose I didn't replace, shows me its butt.. then back to barn... LoL, I think I am getting to the end of nightmare tunnel. I put about 100 hours on it, and have changed all the fluids, and happy it say it still runs and operates great, and it does what I ask. I will be looking forward to learning, and sharing any, and all my experiences with the group.
/ New Member #2
:welcome: to TBN...enjoy.
/ New Member #3
Bob50
Good morning and :welcome:to TBN just keep plugging away doing what you need to keep it running and good luck.
/ New Member #5
Kubota B2150
1988 - 1996
Compact Utility tractor
Previous model: Kubota B9200
Series back: Kubota B1750
Manufacturer: Kubota
Variants:
B2150DT: 4WD
Kubota B2150 Engine:
Kubota 1.2L 4-cyl diesel
Kubota B2150 Power:
Engine (gross): 24 hp [17.9 kW]
Gear PTO (claimed): 20 hp [14.9 kW]
Hydro PTO (claimed): 18 hp [13.4 kW]
Capacity:
Fuel: 7.4 gal [28.0 L]
Hydraulic system: 4.75 gal [18.0 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift: 1014 lbs [459 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540
Mid PTO: standard
Front PTO: optional
Dimensions
Wheelbase: 63 inches [160 cm]
Weight: 1687 to 1841 pounds
2WD Weight (shipping): 1687 lbs [765 kg]
4WD Weight (shipping): 1841 lbs [835 kg]
Length: 109.4 inches [277 cm]
Width: 44.7 inches [113 cm]
Height: 76.8 inches [195 cm]
Kubota B2150 attachments:
mowing deck
front-end loader
Mechanical:
Chassis: 4x2 2WD
4x4 MFWD 4WD
Steering: manual
power*
Brakes: dry disc
Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 4.75 gal [18.0 L]
Pump flow: 7.4 gpm [28.0 lpm]
Page information:
Last update: August 23, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
Welcome to T-B-N.
You may as well change the remaining, aged hydraulic hoses. In my experience once a tractor reaches six years of age, the hoses begin to fail under max loads. Hydraulic hose failures can be dangerous to the operator and dangerous to people observing in the vicinity.
/ New Member #6
G'day Mate and welcome to TBN from Downunder.
Enjoy the site... from wherever in the world you're from.
/ New Member
Thank you all for a warm welcome. I am in North Carolina.. I rebuilt all but one cylinder (I have it apart now) I think it is a good Idea as well to replace the rest of the hoses...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2014 Chevrolet Silverado1500 Pickup Truck, VIN # 1GCNCPEH0EZ393232 (A61165)
2014 Chevrolet...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
