Ford 4000?
/ Ford 4000? #1
Russo52805
Kubota M59
Looking for any help identifying model. We are trying to repair the 3pt (keeps drifting down) and the PTO (won't disengage). It's a 3 cylinder diesel with ram power steering. Thanks y'all. Wes IMG_20191219_063023482.jpegIMG_20191219_062933231.jpegIMG_20191219_062922687.jpegIMG_20191219_062912239.jpeg
/ Ford 4000? #4
/ Ford 4000?
Ok thank you now for trying to find some repair information
/ Ford 4000? #7
Will the PTO not disengage or does it just always spin? I haven't seen a Ford tractor yet that the PTO didn't always spin but when resistance is placed against it it will stop. I will say you can grab it and it will stop but the safety police don't like that so take a 2x4 or 2x4, wedge it between the drawbar and shaft and place pressure against the spinning shaft and see if it stops, then engage the pto lever and see if it doesn't stop with pressure. If that test works out that way then leave it alone and use it. The drifting 3 point can be as simple as the nut on the quadrant holding it all together. Is the quadrant lever moving as well?
/ Ford 4000? #8
If the D makes it a 4000 does the ram steering make it a SU (special utility)?
/ Ford 4000? #9
Post a better photo of the rear end. It looks to me that you have the smaller axles of a 3000.
32ft Flatbed Equipment Trailer (A64556)
32ft Flatbed...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2014 JOHN DEERE 50G EXCAVATOR (A65056)
2014 JOHN DEERE...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2013 CASE 580 SUPER N LOADER BACKHOE (A67714)
2013 CASE 580...
LIPPMANN HEAVY DUTY ROCK SORTER (A66734)
LIPPMANN HEAVY...
