Loader Forks for 1526 100E pin on removable loader
   / Forks for 1526 100E pin on removable loader #1
Scaper
I live in the state of Delaware in New Castle Coun
New Holland 1030
My new tractor is a 1526 with a 100E pin on removable bucket. What pallet forks will work with that set up? If anyone has ever purchased pallet forks please chime in. I was hoping for the skid Steer bucket set up but this loader did not come with that system. Im not sure about how much torsional pressure the clamp on bucket forks place on the bucket itself again anyone that uses these please give me your opinion. Thanks, Big Mark
   / Forks for 1526 100E pin on removable loader #2
I started out with the clamp on style forks.
They're "are what they are". They're not the best, but work. It depends on how rough you are with them and what used for.
Pros:
- Cheap.
- Easy to mount/dismount (until they're not, see "cons").
- Probably most useful for moving actual pallets
Cons:
- Depending on strength of your bucket, loader lift capacity, and your tendency to push the load limit, a heavy load could (and did) give bucket edge a bend ("perma-smile").
- Extends load farther out in front of bucket, reduces/limits lift capacity, and/or need more rear ballast.
- May be hard to see end of fork if its hidden by bucket.
- Rough usage will bend either, or both, the top of the clamp bolt (or handle), or it will bend the bolt at the bucket. This makes it very difficult to unscrew them to remove. You will need a big cheater pipe to unscrew.
- When using them to "dig" under non-pallet items, like root balls, logs, rocks, etc.., and you hit something, they have a tendency for one fork to get knocked "cock-eyed" and no longer be perpendicular to the bucket until you get off and readjust/retighten them.
- - - - For that reason I purchased an "adjustable pallet fork stabilizer" (adjustable spreader bar) that is suppose keep forks parallel with each other. The problem with this is: After a few rough uses the "adjustable" spreader bar gets bent so it is no longer adjustable, but not a problem if you don't need to reset width of forks. Also it's very hard to clamp the metal adjustment bolts of the spreader bar to metal forks. Things shift and the bar comes sliding off the forks into the burn pile (or bon-fire) when you dump the forks vertically (ask me how I know). The solution was to put little shims of wood (branches, whatever I could find) between the metal bolt and fork.
- If moving logs, (IMHO) there's a greater danger of logs rolling down loader arms and taking driver out, as clamp on forks rely on a "backstop" that owner rigs up (usually just flimsy 2"x4"s in stake pockets).
They have their uses, but I eventually sold them and got pallets forks with a frame that swaps out with bucket. I like those a whole lot better.
Thank you so much for the thorough explanation of the two different types I looked at the ones that you put on the bucket and tighten down was not impressed so I think what I am going to do is just leave my bucket on. I have a rear platform lift if I need to just use that I will. I think it would be a lot better off for my tractor safer for me but thank you so very much for everything you sent Big Mark.
   / Forks for 1526 100E pin on removable loader #4
I know You don't want to here about this but the new 2021 M-F 1526H comes with a quick attach FEL! Have You checked out Vahrenberg /Implements they showed a adapter for a quick attach for the FEL on the 1526, Also have You checked with your dealer on what your looking for? I own a 2018 M-F 1526 so I'm always looking for accessories or upgrades for it :unsure: . IMG_20201003_134009.jpg
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
BUYERS PREMIUM & PAYMENT TERMS (A52141)
BUYERS PREMIUM &...
2016 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2016 CATERPILLAR...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
