   / Harbor Freight Tools that don't suck #12,382
Poster is using Font tags, [ SIZE=4 ][ COLOR=#A52A2A ][ FONT=Tahoma ] Size 4 is normal, or one step above, color is a brownish rust, Tahoma is the type style. This is what I see:
Not a big deal for me. Looks and reads fine.
No where near as annoying as the fact that HF seems to have just in the past day or two switched their email images to a secure server which means they no longer display in the older email gathering utility I use. I now have to copy the URL and paste it into a browser to 'View as a Webpage'.
   / Harbor Freight Tools that don't suck #12,383
...and lots better than posters who must post everything in upper case to make their point or so it appears. I don't read their missives.
   / Harbor Freight Tools that don't suck #12,384
WHAT ARE YOU TALKING ABOUT??:laughing:
   / Harbor Freight Tools that don't suck #12,385
Hey PhysAssist, your most recent posts are showing up in huge font sizes and colors. Not sure how it works on this board, but maybe your font default settings got changed? :shocked:
Font is red, but normal sized on my iphone, red and huge on my laptop.
   / Harbor Freight Tools that don't suck #12,386
#1)- see: Which Portable Tire Pump is Best? Let's find out! - YouTube
No, I don't believe he tested Viair, and The Wirecutter does recommend those [https://thewirecutter.com/reviews/best-tire-inflators/], but I had one of the 100-PSI HF models and really liked it- until it froze up [which I now think I have figured out...]
I had a slow leak, and used it a couple of times in the space of 3 or 4 days, and then when I tried to use it another time, it was frozen up [and burnt out my accessory outlet fuses...]
However, when it failed, the ambient temperature had dropped from above freezing to -11F through the day while I was at work on a 12-hour shift, so I think in retrospect, it had gotten some moisture built up from using it the few previous times, and then froze solid when the temps plummeted, but what I don't understand is why it never worked again, and each time I tried it again, it burnt out my accessory fuses.
#2)- After my experiences and breaking my back standing on my head trying to replace the fuses, [and reading the Wirecutter's
recommendations, I didn't want to have to use the cars' accessory outlets any more for this kind of [relatively] high-drain accessories, so I bought an extension cord that has battery clamps on one end, and an accessory outlet [cigarette light port] on the other, so I can run the "directly" off the cars' batteries...
#3)- No, I don't need 150 PSI for my truck's tired, however, the above was one of the reasons, I was thinking of getting the 150 PSI version- it has battery clamps as the OEM connectors.
The other reason were basically that whenever cost isn't a huge factor, I always prefer to get the heavier duty option, all other things being equal...
Especially as I tend to use my tools to their limits, [and sometimes find out that I have overshot somewhat
:confused3:].
The Wirecutter review link did not work. It appears the closing bracket around the link was inadvertently included in the link you posted. Deleting that bracket got it working. Here's a working version of the link: The Best Tire Inflators for 2019: Reviews by Wirecutter
I agree with you about the desirability of electric leads which clamp on to the battery.
However, for my wife's vehicle, the convenience of plugging in to a cigarette lighter was the major consideration. Unfortunately, as it seem you discovered, some vehicles (particularly smaller ones) have the lighter plug on a 10 amp fuse. Many of these compressors draw 15 amps. My wife's is the one vehicle we have with a 10 Amp circuit. I almost bought the Wirecutter's recommended Viair 78P compressor for my wife's vehicle (by coincidence - I had not seen their review). However, it can draw up to 15 amps. The Viair 75P I ended up getting her draws less than 10 Amps, but still has a speedy fill time (they get this by setting the compressor up for higher volume, but limiting the max pressure to 50 PSI).
Tip on avoiding popping fuses when using a cigarette-lighter powered compressor:
I noticed that what often popped fuses for me in some vehicles when using a cigarette-lighter socket for power was starting or stopping the compressor under load. I found if I left the compressor disconnected, started it up, then connected it to the tire, and when done filling kept the compressor running, disconnected the hose from the tire, then shut off the compressor, I did not blow fuses. You can get a surge when starting or stopping an inductive load like an electric motor. If you reduce the load on it by not having it connected to a (even partially) pressurized tire, you reduce the surge, and may get by without blowing the fuse. This was the only way I could get our "Slime" brand compressor to work in our Toyota Minivan without popping fuses (interestingly, it was the "off" cycle which most often blew the fuse).
   / Harbor Freight Tools that don't suck #12,387
I picked up this bending brake from harbor freight for like 65 bux, it's doing ok.
   / Harbor Freight Tools that don't suck #12,389
Viair is also 3 times the cost of the HF compressor.
Viair also works many years later in the middle of the boondocks with no cell coverage. I have one mounted under my truck for the last 7 years. It's never failed me, although there is a slow leak somewhere which is probably the check valve.
   / Harbor Freight Tools that don't suck #12,390
No, actually, it's not.
The Viair 78P which was the top rated compressor in the Wirecutter review that PhysAssist linked is currently on sale on Amazon for $38.25 (regularly $45.95). That sale price is just a couple bucks more than the HF Pittsburgh 100 PSI tire inflator. The Viair 78P also has a 30 minute duty cycle at 30 PSI. If my wife's car had been able to handle the 15 amp rating on it, I'd have jumped on it. (The larger 88P I got for my truck runs $59.39, and is well worth it if you are inflating large tires.)
SKID STEER BUCKET (A58214)
SKID STEER BUCKET...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
20' STICKS OF 1/4" T OF 2" - 3" & 1 1/2" FLAT (A58374)
20' STICKS OF 1/4"...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2011 International DuraStar S/A Refer Truck (A55272)
2011 International...
