They can stick Bobcat tractors where the sun don't shine.
   / They can stick Bobcat tractors where the sun don't shine. #43
the CT335 may be unsupported because of it's age, Bobcat did stop making tractors for a long time, and now have a new line!.. like I said before, ask YOUR dealer if the CT335 is still supported!..
All of the engine parts and replacement engines are all available for this tractor. This engine is still fully supported.
Hope this helps
   / They can stick Bobcat tractors where the sun don't shine. #45
Hope this helps
Thanks MichiganIron!
I knew something was wrong with the OPs story, along with all the fake news doods who piled on!
   / They can stick Bobcat tractors where the sun don't shine. #46
Only one things to say....CHEAP[ LABOR
.....and hardly any rules pertaining to the environment during the whole manufacturing process.
   / They can stick Bobcat tractors where the sun don't shine. #47
Not to mention we never learned what was wrong with his tractor. Could have been something like a head gasket for all we know. If his story was just like he related, then he needs to be getting legal representation for having his tractor disassembled and all the engine parts left outside in the weather. He never did mention what he was going to do about all of this, Just wanted to make sure we understood that Bobcat tractors are no good, and cannot be repaired either by a Bobcat dealer or a Kioti dealer. And they will just disassemble them without any diagnosis of the actual problem, and then throw up their hands and leave the owner to gather up the pieces literally. He is going to "hurt" Bobcat by not buying another thing from them. He just wanted us all to know we are fools for investing in either Bobcat or Kioti products as we will not ever be able to get service or repair of them. I would give 50 cents to know what really happened or some pictures of the tractor parts strewn about. What say you Original Poster? What ARE you going to do?
   / They can stick Bobcat tractors where the sun don't shine. #48
A "dead" cylinder could be as simple as a problem with one valve....not a big deal. Hopefully, the OP's tractor is repairable....after the snow melts and all the parts are found.:eek:
   / They can stick Bobcat tractors where the sun don't shine. #49
Well it does look like he has had the tractor for quite a while and really liked it.:
26-2010, 07:58 PM
Thread: Bobcat or Not....
by Luke McGlukeReplies
22
Views
3,408
Re: Bobcat or Not....
I have the 335CT with an 8TL FEL, 68" bucket, forks, rear blade and fluid filled tires. A lot of tractor for an acerage. Don't need nor want anything bigger. It's great for logging, clearing snow,...
05-11-2010, 09:14 PM
Thread: What would you do
12
Views
1,651
Re: What would you do
I was in the same situation last summer. Decided to go with the 335CT and boy am I glad I did! The extra power and weight allows me to carry bigger logs and is perfect size for putting in and...
12-22-2009, 05:11 PM
Thread: Tractor- An Expensive Toy, ...until the big one hits
33
Views
6,126
Re: Tractor- An Expensive Toy, ...until the big one hits
LOL Yeah, here in northern Minnesota I'm the tractor guy in our neighborhood. My 335 Bobcat plows snow for the weekend neighbors from Minneapolis. Brings in area lake docks, and is an invaluable...
I feel bad for the OP he may have been taken for a ride on the trouble shooting and diagnosis of the root problem. Then WAS given inaccurate info on replacement parts.
$2000 to change 3 injectors then say tough luck... I would be more than a little ticked off to. That is a parts changer not a mechanic. Could even just have been in need of a valve adjustment.
Here is hoping he finds a knowledgeable mechanic that can salvage this situation since parts are obviously readily available.
   / They can stick Bobcat tractors where the sun don't shine. #50
I think there is more to it. Korea is not a particularly cheap labor market today. If the only concern was labor cost, they would be building them in China, Cambodia or somewhere in Africa. Having spent a lot of time in Korea, I think the key is educated hard working labor at a reasonable cost.
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
ABO TANK (A50854)
ABO TANK (A50854)
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
