Hey, piranha tooth bar people!
   / Hey, piranha tooth bar people! #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
Yes, I know, the piranha tooth bar is the cat's meow per all accounts. I need some input regarding a particular application, clearing tall thick grass and cattails, how's it with that? Specifically, does it cut through that stuff or just grab it and pull it out by the root?
I have a ratchet rake which is great for pulling everything out by the roots, but am looking for more or less knocking that stuff down without necessarily yanking it all out. I have a bunch of wetland I wanna plant trees in next spring, but don't wanna leave everything bare around them, and then having to reseed and so forth.
   / Hey, piranha tooth bar people! #2
The cattails will probably cut off okay but the grass not so much, unless it is fairly stiff, otherwise it most likely will just push over. I do love my piranha .
   / Hey, piranha tooth bar people! #3
Kinda all 3, cut,rip and pull when I did the 32foot x 45foot area I still needed to go over it with my teeth on the box blade to rip ot roots that were left behind.
Before.
After.
Cleanup with box blade teeth.
   / Hey, piranha tooth bar people! #4
Couple more.
Hey Jim, yeh I seen you post that before. That second pic looks promising for my purposes.
Here's what I'm gonna be dealing with:
I knocked all this down last time with a walk-behind brush hog I rented. You can't see it, but around 8 ft into that jungle is a wire fence I put up, that's also when I planted the trees in there.
That be cool by me, actually. I could mow through the grass with a few passes after that.
   / Hey, piranha tooth bar people! #9
Different applications, different results, I guess. My Piranha doesn't cut anything. It just pushes it. Sometimes that rips bushes out by the roots, sometimes it just pushes them over.
If I want to clear to bare earth, it is great. But it doesn't act like a lawn mower in any way. For me.
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
NEW Skid Steer Attachment Plate (A59000)
NEW Skid Steer...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
Caterpillar 906M (A53317)
Caterpillar 906M...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58214)
2014 MAGNUM...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
