Hey, piranha tooth bar people!
   / Hey, piranha tooth bar people! #1
GeneV
Elite Member
Lake County, IL
Bradley 48" stander MF GC1710
Yes, I know, the piranha tooth bar is the cat's meow per all accounts. I need some input regarding a particular application, clearing tall thick grass and cattails, how's it with that? Specifically, does it cut through that stuff or just grab it and pull it out by the root?
I have a ratchet rake which is great for pulling everything out by the roots, but am looking for more or less knocking that stuff down without necessarily yanking it all out. I have a bunch of wetland I wanna plant trees in next spring, but don't wanna leave everything bare around them, and then having to reseed and so forth.
   / Hey, piranha tooth bar people! #2
The cattails will probably cut off okay but the grass not so much, unless it is fairly stiff, otherwise it most likely will just push over. I do love my piranha .
   / Hey, piranha tooth bar people! #3
Kinda all 3, cut,rip and pull when I did the 32foot x 45foot area I still needed to go over it with my teeth on the box blade to rip ot roots that were left behind.
Before.
After.
Cleanup with box blade teeth.
   / Hey, piranha tooth bar people! #4
Couple more.
Hey Jim, yeh I seen you post that before. That second pic looks promising for my purposes.
Here's what I'm gonna be dealing with:
I knocked all this down last time with a walk-behind brush hog I rented. You can't see it, but around 8 ft into that jungle is a wire fence I put up, that's also when I planted the trees in there.
That be cool by me, actually. I could mow through the grass with a few passes after that.
   / Hey, piranha tooth bar people! #9
Different applications, different results, I guess. My Piranha doesn't cut anything. It just pushes it. Sometimes that rips bushes out by the roots, sometimes it just pushes them over.
If I want to clear to bare earth, it is great. But it doesn't act like a lawn mower in any way. For me.
LOT: (2) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (2) Kimball...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Cat Mixer RM-250C (A55973)
Cat Mixer RM-250C...
